09-27-2017, 08:41 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | CM2QLM 1.15 can't open |
09-27-2017, 12:40 | #3 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | no anti virus installed . And no any other software installed. Just installed 1.15 and its not working. And its common for my both PC. Normally I am not installing same software on my both PC. |
09-28-2017, 02:45 | #5 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Pc has installed team viewer and asus link. I uninstalled now. But situation same. Then I installed CM2QLM 1.12 just check and I saw this error "Smart-card not have active module" Whats that mean? Whatever now situation is good better than before. Because at least I can see a error now |
09-28-2017, 04:02 | #7 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | server mistake and 3 times posted accidentally. Sorry and delete last same two post. And upper two also with wrong image tagging |
09-28-2017, 04:16 | #8 (permalink) | |
Insane Poster Join Date: Apr 2009
Member: 1005456 Status: Offline Thanks Meter: 39 | Quote:
Here is what i do.. This solution is not For long time you need to do this every time it happen.. Ok.. Try to Uninstall Cm2QLm then Delete remaining whole folder of Cm2QLm on DRIVE C: InfinityBox.. Then try to install it again and Test if it's Run properly. But for me i stay on Version 1.14 because of that Bug.. | |
09-28-2017, 10:21 | #11 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | @InfinityHelp Sorry..... Just wanna explain clearly and wanna resolve this soon. So what I do now? As the message my dongle also already block by server |
