06-29-2017, 09:37 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: BetaMax Tester
Member: 516470 Status: Offline Thanks Meter: 70 | CM2QLM Error : Prepare target failed! Unsupported CPU EDL mode Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 00849DEF ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : 90631C1E2BE19B91 ID_BLOCK_L : 1FB40806846F8EC6 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU or unknown SBType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! --------------------------------------------------------------------------- Operation : Reset Settings [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 00849DEF ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : 90631C1E2BE19B91 ID_BLOCK_L : 1FB40806846F8EC6 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU or unknown SBType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
