03-27-2018, 17:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | CM2QLM have suport for this: BBK vivo Y79a ( BBK Vivo Y79A Dual SIM TD-LTE CN | Device Specs | PhoneDB ) CPU: Manufacturer Qualcomm Snapdragon 625 MSM8953, 2016, 64 bit, octa-core, 14 nm, Qualcomm Adreno 506 GPU Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Driver is ok..from infinty directory /CM2QLM/Drivers ... emergenydownloaddriver Some help ??? Phone have security code.... If i reset from recovery....I belev that i must unlock frp BR mihnea |
03-27-2018, 20:31 | #3 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Yangon Age: 29
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | CAN u add Samsung SCV33 Qualcomm Loader in infinity box ? I got the test point and I am enter the 9008 mode. I want to flash the firmware my phone is dead in sbl upload mode plz help brother infinity team support thanks a lot and respect to all Sent from my MI 6 using Tapatalk |
03-28-2018, 08:02 | #5 (permalink) |
Member: 52722 Status: Offline Thanks Meter: 18 | Helloo I reset device, I reset power, I restart pc I try diferent USB, I read other phone who was readed ok, I change PC with my laptop who is clean, fresh divers... Same result...like in first post.... maybe not suport this type of procesors, or soft don't have corect loaders. I dont know Br Mihnea |
03-28-2018, 11:34 | #6 (permalink) |
Member: 52722 Status: Offline Thanks Meter: 18 | finely it works... I dont knlow... how !!! same pc, same drivers same box,.... same restart.... Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 99E34384 ID_BLOCK_L : AD6853B23DA0712DE94329CD2914A8FB ID_BLOCK_L : BCE17B8E668CAB1C65F21657F0142973 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
