11-05-2016, 05:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | CM2QLM Kyocera c6740n support was trying to reset this phone had to use EDL cable to force it. but then I get: Code: Operation : Reset Settings [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0C8E2E27 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 00C22A60E316CE61 ID_BLOCK_L : 7233E4F9729BE47B Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-05-2016, 05:48 | #2 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | this one zte z755 I dont know which CPU exactly it has I had to force EDL also This is log I could get Code: Operation : Read Flash [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 0BCB8115 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 02BF166B572EC7C2 ID_BLOCK_L : 4CD64C51B6CEB0F7 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-07-2016, 01:04 | #4 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | [QUOTE=JorgeVla;12141295]ZTE Z755 have Qualcomm Snapdragon 200 MSM8210 inside.[/QUOTE? Thanks, good to kniw... not supported for now... |
11-07-2016, 17:59 | #5 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | now tried kyocera c6745, and got same result Code: Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 15C84ED8 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 00C22A60E316CE61 ID_BLOCK_L : 7233E4F9729BE47B Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-10-2016, 16:08 | #14 (permalink) |
Freak Poster Join Date: Jan 2015
Member: 2329547 Status: Offline Thanks Meter: 15 | take a look hello, i found something for you, take a look at this link you may find it useful. http://cdn.kyoceramobile.com/support...ernel_code.zip Kyocera Phones Support For Developers need support for this phone so badly. thanks |
11-10-2016, 17:58 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Unfortunately had checked that at first report about unsupported device. Not much interest stuff inside |
