Old 07-05-2017, 19:22   #1 (permalink)
Member: 220595
Thanks Meter: 355
cm2rkt latest, still no rk312x support ?
I have two tablets with rk3128 cpu and everytime I try to connect for any function
I get this error:
----- > Phone/Tablet :
1. Power Off device
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Device connection test not passed! Breaking!
Probably you boot device in wrong mode!
one tablet is stuck at boot logo, the other tablet was also but I soled by hard reset via volume keys.
But I want to make a backup of firmware...
Old 07-05-2017, 19:40   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Seems as Android 6 devices with protected BL , or wrong connection mode.
V2.01 can make things clear. Tomorrow.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 07-05-2017, 20:19   #3 (permalink)
Member: 220595
Thanks Meter: 355
@JayDi
android 5 both of them.
I can connect and read firmware with other tools, right now dont remember the name of such free tool.
however files cant be written.
thanks for your attention.
Old 07-05-2017, 20:26   #4 (permalink)
Member: 220595
Thanks Meter: 355
rkdumper is the tool
here is output from rkdumper info
A:\GSM\tablets\rockchip\rkDumper_102>rkDumper.exe info
        rkDumper (version 1.02)
        Utility for Rockchip's firmware backup
        (c) RedScorpio, Moscow, 2014-2016
            [email protected]
        ==========================[ START ]==========================
        -- Devices enumerating --
        Devices table (found 15 USB devices):
        1       Device #0: USB Root Hub
        1.1     Device #1: USB Hub
                VID = 0x8087, PID = 0x0024, REV = 0x0000
        1.1.4   Device #2: USB Hub
                VID = 0x05e3, PID = 0x0606, REV = 0x0702
        1.1.4.1 Device #3: e-gate Smart Card
                VID = 0x0973, PID = 0x0001, REV = 0x0100
        1.1.4.2 Device #4: USB Serial Converter
                VID = 0x0403, PID = 0x6001, REV = 0x0400
        1.1.6   Device #5: Microsoft Mouse and Keyboard Detection Driver (USB)
                VID = 0x045e, PID = 0x07b2, REV = 0x0704
        2       Device #6: USB Root Hub
        2.1     Device #7: USB Hub
        2.1.3   Device #8: Dispositivo compuesto USB
                VID = 0x1a2c, PID = 0x0b23, REV = 0x0110
        2.1.5   Device #9: USB Hub
        2.1.5.1 Device #10: Alcor Micro USB Smart Card Reader
                VID = 0x058f, PID = 0x9540, REV = 0x0120
        2.1.5.2 Device #11: USB Serial Converter
                VID = 0x0403, PID = 0x6001, REV = 0x0600
        2.1.6   Device #12: Rockusb Device
                VID = 0x2207, PID = 0x310d, REV = 0x0100
        3       Device #13: USB Root Hub
        4       Device #14: USB Root Hub
        Found:  LOADER device (RK3126 2207:310d) #12
        FlashInfo
        Manufacturer:   Hynix (0x02)
        Flash size:     8480MB (0x01090000)
        Full size:      8480MB (0x01090000)
        Block size:     4096KB
        Page size:      16KB
        ECC bits:       40
        Access time:    32
        Flash CS:       0 (0x01)
                CS0: ad de 14 a7 42
        ==========================[ STOP  ]==========================
and read firmware output:
            [email protected]
        --- Firmware dumping ---
        Found LOADER Rockchip device
        First 0x0008 NAND blocks reading
        PARM sign found
        Begin of partition "radical_update" don't matched end of partition "system"
        FlashInfo
        Block size:     4096KB
        Page size:      16KB
        ECC bits:       40
        Access time:    32
        Flash CS:       0 (0x01)
        Partition "uboot"               saved (format: Rockchip uboot image file)
        Partition "misc"                saved (format: unknown)
        Partition "resource"            saved (format: Rockchip resources image file)
        Partition "kernel"              saved (format: RockChip KRNL signed file)
        Partition "boot"                saved (format: Android boot image)
        Partition "recovery"            saved (format: Android boot image)
        Partition "backup"              saved (format: unknown)
        Partition "cache"               saved (format: ext4 image)
        Partition "metadata"            saved (format: ext4 image)
        Partition "kpanic"              saved (format: unknown)
        Partition "system"              saved (format: ext4 image)
        Partition "radical_update"              saved (format: unknown)
        Partition "frp"         saved (format: unknown)
        Partition "userdata"            skipped
        -- Rockchip LOADER device resetting --
        Command to reset sent successfully
        Command to reset confirmed
        Configuration file for RKAndroidTool v.1.xx (8-bit) created
        Configuration file for RKAndroidTool v.2.xx (16-bit) created
Page generated in 0.16272 seconds with 8 queries
