01-13-2020, 18:42 | #1 (permalink) | ||||
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | CM2SP2 Module 2.04 "Unsupported Phone" I Am Facing Some Issue With CM2SP2 Module "Let Me Also Clear This Mobile Not Supported With Earlier Ver Too" Issue Description :- When U Flash This Mobile Phone Handset Flash Ok But After Flash Sim Not Detect SL Damaged After Flash But IMEI Ok...Phone Having Customized Firmware... When I Try To Write NV From Another Handset It Show Error Quote:
When I Select Pac N Make Identify Then Also I Got Error Quote:
Phone With Issue (After Flashing) Quote:
Ok Handset Quote:
In 1 Log Simlock Type In Other That Is Missing ...Can U Help Me To Rebuild Security Area For This Type Of Handset..If U Need Anything Else Let Me Know I Am Having NV Backup With Diag If U Need Let Me Know.. Waiting For Reply | ||||
01-14-2020, 12:10 | #3 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Device Connected! BootVersion : SPRD3 Boot : PAC : q402plus.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... ERROR : FLASH FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl! Change settings! Reconnect Power/Cable! Same Issue My Friend.. |
01-14-2020, 14:03 | #5 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Can U Explain Friend What U Did Means Which Operation U Are Talking About...If U Talking About Flashing Yes I Also Done Flashing With It...Q402+ Came In 3-4 Variant...My Phone Having Custom Firmware..Can U Post Image Extracted Pac Files So I Can Check N Know U Are Talking About Which Phone Or Post SW Info |
01-14-2020, 14:37 | #6 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
set is bounded with Jio ! its Raman sing Gov gave ( You know ) i try for SP unlock but not success before that i read NV also and after unsuccessful in SP lock i write backup is this same phone in your hand ? or different ? | |
01-14-2020, 18:57 | #7 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
Yeah Same Phone In Hand..Someone Erase Simlock Area Somehow I Repair Security But Now Sim Not Work Show Forever Locked @ Notification Panel Area..About SP Unlock I Am Having Something For This Handset Let Me Test On Ok Handset If Work I Will Share With You...But Right Now I Am Struggling With This 3 Handset With Same Issue In Hand.. I Need Some Solution TO Rebuild Its Simlock Area..As Its A Signed Type Phone | |
