12-23-2016, 07:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2457240 Status: Offline Sonork: 100.1662388 Thanks Meter: 76 | colpad 362a frp solution plz any solution Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.06 Operation : Identify [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0613998B ID_BLOCK_I : 009600E1 ID_BLOCK_L : D91AC86ECCF96CBABDED1BE914577F85 ID_BLOCK_L : 6C93143E15B76A6E44BAC7A053590E3C Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to ramanmobile For This Useful Post: |
12-23-2016, 09:49 | #2 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: IRAN 16
Member: 2375199 Status: Offline Sonork: 100.1651762 Thanks Meter: 107 | Quote:
your answer is in your log!!! | |
12-23-2016, 09:58 | #3 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
just contact me after ready the firmware | |
