10-20-2009, 23:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 407810 Status: Offline Thanks Meter: 18 | com port infinity IMEI change problem for CPU MT6225 ferrari phone new medium size i try all the codes here and there is no code to enable com port for me as i can`t change the imei number via infinity if comport is not activated. Please some one give some advise. does spiderman box can change the imei without original usb cable? I now phone is :CPU MT6225 as when i connect it to pc as a webcam it comes CPU MT6225 first and then install it automaticly. help pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. phone take nokia small pin charger and on the side it take usb cable and port looks similar to d800 samsung |
10-21-2009, 06:45 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
10-21-2009, 16:58 | #5 (permalink) |
Member: 407810 Status: Offline Thanks Meter: 18 | Can you explain more, do i need to use the test point rj45 cable to change the imei? i have 70 Pcs of this phones it will be big problem to do them this way. also do you know if the spider man machine can do this more easy than infinity as i have the infinity and will buy the spider man if it can do the job quick. Thank you, Regards |
10-22-2009, 08:07 | #6 (permalink) | |
10-22-2009, 17:33 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of you must assemble com port cable. with a help of it you will be able to use all IMEI changing methods. (1,2,3) new 6225 cables do not have internal usb<>com port convertor. those are regular USB cables, which is not usable for IMEI change with any of methods. what is your phone connector type? I am sure, with my help, you can assemble cable much more faster than waiting for pinout finding box. |
10-22-2009, 20:42 | #8 (permalink) | |
Member: 407810 Status: Offline Thanks Meter: 18 | Quote:
i did many of this phones like ferrari and n97 and iphone(chinees) before but this new phones they wont give me option for comport when i connect them via usb cable wich comes with the phone. here is picture for new ferrari. i have 60 Pcs of them, thank you in advance. | |
10-23-2009, 23:08 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! power on phone take multimeter set it to "V" (voltage measuring) one multimeter probe put to some grounded phone part. connector shield is also OK. with another proble touch one by one each connector pin. check each pin voltage. when you see voltage between 2,7...2,9- those are Tx/Rx find them and we will continue with instructions of assembling own cable |
10-24-2009, 11:36 | #11 (permalink) |
Member: 407810 Status: Offline Thanks Meter: 18 | Hi, Thank you for all your help. i just bought the infnity pin finder and is on the way. as i have 5 different model of this phones with different cables so it was better to buy pinfinder to make the jub faster. as much as i know with the pinfinder cables i don`t need to modify cable for this phone, is this correct? Once again Thank you. best Regards, Saeed |
The Following User Says Thank You to saeedhex1 For This Useful Post: |
10-26-2009, 16:08 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
yes, using pinfinder you dont have modify cables. sometimes phones dont keep tx/rx in system connector. only in this case you must disassemble phone and search for test points on PCB. by my own experience- this is happening in 5%-10% of cases | |
10-26-2009, 22:48 | #15 (permalink) | |
Thank you | |
21/10/2008 new big samsung update all samsung 3g direct imei change added for freee | samigsm78 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 40 | 12-05-2010 23:03 |
com port infinity IMEI change problem for CPU MT6225 ferrari phone new medium size | saeedhex1 | Chinese Models & Cloned Phones | 0 | 10-20-2009 23:19 |
21/10/2008 new big samsung update all samsung 3g direct imei change added for freee | tito millo | Service Products News & Updates | 0 | 10-21-2008 23:20 |
After imei change on T29 can't flash the phone | roniri | Old Ericsson Phones & Sony Phones | 1 | 09-06-2002 00:12 |
