Old 06-08-2018, 15:00   #1 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
Comio s1 error
AFTER HARD RESET PHONE IMEI NULL
OR IM TRAY REPAIR THEN THIS ERROR
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
[DA_ERROR] : 00200000
Boot Error!
Operation Failed
Elapsed: 00:00:28
Reconnect Power/Cable!
OR USE V2 R4
SAME NOT SUPPORT ERROR USE ALL METHOD ONE BY ONE SELECT ALL MODEL OR BOOT
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM3)
MODE : PRELOADER PORT
PORT : 3
Waiting BOOT ack ...
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
Info : Device is not supported yet!
ANY ADVISE THANKS IN ADVANCE GREAT TEAM CM2
Old 06-08-2018, 15:26   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
load scatter file into old 1.58 mtk and connect set into brom mode will be ok
tested....
Page generated in 0.18651 seconds with 8 queries
