12-06-2014, 21:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | RDA unlock possible ? it is coolsand CPU here log Code: Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:04 Done Reconnect Power/Cable! I tried formatting and repairing security but none of this solved. I Cant find any infoirmation on the net regarding the info on the phone label. here log from reading full flash (project info, etc) Code: Start at : [06/12/2014 / 13:22:20] Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : BV1_0_5 Project Info : al_51a_128x160_KRT_5169_NX14_LOCKSIM_SINGLE_CARD_5.0 Compile Date : 20131102Sat1341 [BIN] Saved as : BV1_0_5_al_51a_128x160_KRT_5169_NX14_LOCKSIM_SINGLE_CARD_5.0_CT8851A_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : E:\boxes\InfinityBox\CM2RDA\Flash\IFF\BV1_0_5_al_51a_128x160_KRT_5169_NX14_LOCKSIM_SINGLE_CARD_5.0_CT8851A_flsh_spi32m.iff [CAL] File saved to : E:\boxes\InfinityBox\CM2RDA\Flash\IFF\BV1_0_5_al_51a_128x160_KRT_5169_NX14_LOCKSIM_SINGLE_CARD_5.0_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:04:34 Finish at : [06/12/2014 / 13:26:54] Reconnect Power/Cable! if I upload the full flash to support will you infinity guyes be able to remove the simlock from the flash file and upload unlocked flash file to support area ? |
