05-23-2018, 14:24 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Tinzawatine Age: 44
Member: 175273 Status: Offline Thanks Meter: 68 | connecting problem with qualcomm phones . |
05-23-2018, 14:29 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Infinity CM2 Qualcomm module will not work with that driver. Download below setup and install. Nokia_Care_Suite_5.6.134.1513 www.gsmflashfile.com Reboot ur PC after successful install. Now delete old driver and install manually |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
05-23-2018, 14:44 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Download and install QLM driver from support area.Connect phone and manually upgrade driver to Emergency connectivity from device manager. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-23-2018, 14:46 | #4 (permalink) | |
Member: 175273 Status: Offline Thanks Meter: 68 | Quote:
05-23-2018, 15:39 | #5 (permalink) |
Member: 175273 Status: Offline Thanks Meter: 68 | Thank you all ! My problem is solved via your helps ! Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 086F474D ID_BLOCK_L : 5AAAC03E9905323DEA5FB19E5920B098 ID_BLOCK_L : 2A59E7464BDA048104F3A41D179E88B3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
