Old 05-31-2007, 19:35   #1 (permalink)
Member: 426005
connection problem
can someone please help me im using this infinity box
i have read threads for over three months i still can't
get no response i tried unlocking a c139 tracfone i cut
the trace already phone no longer powers up but it wont
connect in repair module i also tried on a unlocked digicel
c139 same problem
Log opened: [5/31/2007] [11:01:36 AM]
App: C:\Program Files\InfinityBox\RepairModule\RepairModule.exe
Loading data, wait...
[Infinity Box] v1.12
S/N: 0AB0:010A
Wait...
Current model: Moto C113,C114,C115,C116,C117,C118
Done
Current model: Motorola C138,C139,C140
Loading file v.01...
Moto_c138_c139_c140_RepairData_Rev01_standard.31R. bin Loaded
COM11 selected
Device: Motorola C138,C139,C140
Checking data, wait...
Action: Flash write
Write: Repair data
Boot...
Press Power button now !
Err: boot error[02]
Boot Fail
Finished, time used: 1277 sec
Remove/Install battery now !
Old 05-31-2007, 19:55   #2 (permalink)
Member: 148515
hello!
if phone dont power on after you cut track- means you cut right track.
do you set latency value of comport to value 4?
also did you modify cable as it shown in cable selector?
maybe you cable doesnt fit in in phone properly
Old 05-31-2007, 20:04   #3 (permalink)
Member: 426005
i set the value to 4 but was not aware that cable has to be modified
i'm using a x60 cable where is the diagram on how to modify it
Old 05-31-2007, 20:14   #4 (permalink)
Member: 148515
hello!
please run shell program and in cable selector check for g50 pinout.
cable picture 2 and 3 shows how you have to cut rubber to make connector fit in phone better. Modify your x60/t191 cable like there and try again
Old 05-31-2007, 20:27   #5 (permalink)
Member: 426005
i tried that it
made no difference
maybe mt setteings are off
model:
motorola c138, c139,c140
com port
com-11
auto- unchecked
rts line on/off-checked
dtr line on/off -checked
backup system area-checked
erase retries in case of error 5
write retries in case of error 5
defualt protocol
Old 05-31-2007, 20:30   #6 (permalink)
Member: 148515
hello!
are you sure in com port? did you unlock other phones on this port?
about t191 cable: do you have in history success work with it?
Old 05-31-2007, 20:34   #7 (permalink)
Member: 426005
in device manager
usb serial port-com 11
....i have had no sucess with this box at all
but cable works fine in smart clip
Old 05-31-2007, 20:46   #8 (permalink)
Member: 148515
hello!
smartclip rj45 cable has different pinout, i just checked.
use that one which you get with infinity box
Old 05-31-2007, 20:49   #9 (permalink)
Member: 426005
i didn't get a t191 cable with my infinty only a panasonic x60 which my dealer told me will work the same
Old 05-31-2007, 20:53   #10 (permalink)
Member: 148515
i thought you using smart clip cable with infinity box.
but anyway infinity x60 cable should not work with smart clip
they have different pinouts
Old 05-31-2007, 20:55   #11 (permalink)
Member: 148515
please drop me a mail to infinityremoteupdate@yahoo.co.uk
i will reply with one idea
Old 06-01-2007, 23:50   #12 (permalink)
Member: 426005
my x60 cable was bad i used another x60 cable from a friend and boxed worked great thanks infinity team
Vodafone 541 / Alcatel OT-708 Connectivity Problem / Unlocking Problem [ANSWERED] Mr.Ultimate PolarBox 2 12 12-28-2009 17:40
L6 not connected problem, is it a USB Driver problem? astra12 P2k Series 0 11-15-2006 14:59
Connection Problems ramborabbit Alcatel & TCL Old Models 0 05-21-2001 20:00
Connecting problem Fai555 x1x to x45/x50 1 05-11-2001 10:26
c35 cable connect problem Fai555 x1x to x45/x50 0 05-06-2001 13:43
Page generated in 0.29187 seconds with 11 queries
