07-11-2006, 05:40 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Age: 48
Member: 13329 Status: Offline Thanks Meter: 15 | Connection Problem (Com Port) 1- Check attached image of Device manager, all necessary devices are installed. 2- Newly created comport in Ports area (USB Serial Port) is port COM5, but when try to open com5 in v170 module, It just can't. It says port unavailable. There is no other soft open that can be using this port. 3- I'm connecting my cable to the connector along side rx and tx leds 4- The switch in the front is set to FBUS (UP) and in the Back is set to ON 5- There is no green light activity after software starts searching for phone 6- OS is WinXP Pro SP2 7- No USB Hub is used 8- Box is updated to latest soft I don't know any other details that can I say to you. Any other thing you need to know, ask. Please I need to flash this phone with v171 flash. Any help will be appreciated. |
07-13-2006, 02:53 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | better solution is you remove all others box and hubs. I have to way to resolve this problem. 1/ Go to start/my computer/ right clic on mouse and choose manage to open computer management. on left menu choose device manager go to ports(com & lpt) expand the sub menu and see what is com port number of usb serial port. And choose this com port into infinity program. You can also in same menu (computer management) select view and "shows hidden devices" 2/ Open an infinity module and go in settings see connection and choose the port for me for exple it's com-4 vcp0 for my usbbox and com-2 vcp1 is my infinity socket. br Last edited by snsoftkiller; 07-14-2006 at 02:21. |
07-18-2006, 06:10 | #5 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 41
Member: 70573 Status: Offline Thanks Meter: 24 | another resolve this problem I use infinity box plus + cable on the box moto C261(USB to COM)-------> Read flash,Write flash, Read code(Phone lock) is OK I think problem is the cable include Box Infinity Team Pls post Pinout infinity box Plus( It same pinout Old infinity box?image attach) and Pinout T191 cable Thanks |
Vodafone 541 / Alcatel OT-708 Connectivity Problem / Unlocking Problem [ANSWERED] | Mr.Ultimate | PolarBox 3 | 12 | 12-28-2009 18:40 |
vag.com 805 canbus connection problem | si2252 | ECU & IMMO | 0 | 09-29-2009 00:01 |
where to connect the com cable | malta | VygisToolbox | 2 | 10-25-2007 13:40 |
L6 not connected problem, is it a USB Driver problem? | astra12 | Motorola P2k | 0 | 11-15-2006 15:59 |
com connect problems help pls? | Lombard | TOTAL MultiServer | 5 | 04-06-2005 04:38 |
