10-15-2007, 04:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | connection problem-E-PDA v16 I put the box in F-BUS mode. COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 58 sec Remove/Install battery now ! I tried all the procedure as the supporter said! (This image for the supporter's database) |
10-15-2007, 09:30 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 46
Member: 138982 Status: Offline Thanks Meter: 138 | hi I think u can try with C115 com cable. cut the pin of that cable & use blue wire as TX & white as RX. select com 1 in infinity box & connect rx & tx of cable to the PCB's RXA & TXA & then try salim |
10-15-2007, 11:50 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! both ways are correct. via box or via c115 cable. if you use box: connect box rj45 pin 8 to phone gnd pin. connect tx_a pin to box pin 3 connect rx_a pin to box pin 2 |
10-17-2007, 08:00 | #5 (permalink) |
Member: 304090 Status: Offline Thanks Meter: 210 | Now I've finished 2 chinese phones.(restart with sim problem) Thanks for sallupat and our InfinityHelp. I used modified T191 cable as sallupat said.It's very easy! Here is my 1rst phones logs.. Before Action4 I did "Format FFS -safe" (Imissed the log) Last edited by aikonmani; 10-17-2007 at 08:07. |
Mizar help!! Problem with pda flasher | TALIAT | Cruiser Suite | 2 | 02-27-2009 20:09 |
usb drivers and pin no. for e-pda v16 n95 like china mobile | jay_bhayani | HTC & PDA WM( With Touchscreen) | 0 | 08-19-2007 09:38 |
L6 not connected problem, is it a USB Driver problem? | astra12 | Motorola P2k | 0 | 11-15-2006 15:59 |
Big Problem with PDA ver F60048 | nikist | Motorola Old Legacy (EMMI) | 0 | 04-08-2003 23:47 |
Problem with PDA in 9110 | Skoku | Nokia Hardware & Hardware Repair | 5 | 08-24-2002 17:45 |
