Old 06-19-2016, 12:59   #1 (permalink)
SOFTWARE.HELP's Avatar
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 323
Connection Problem or invalid MMI code Error!
I9060i Connection Problem or invalid MMI code Error
not call sent Plz Help Me
The Following 2 Users Say Thank You to SOFTWARE.HELP For This Useful Post:
Old 06-19-2016, 20:17   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,206
bro, check baseband & imei,try to repair Nv & imei.if dont work flash with good Firmware.
The Following 2 Users Say Thank You to Kirumira For This Useful Post:
Old 06-20-2016, 08:13   #3 (permalink)
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 323
IMEI baseband and NV OK But not call sent
you Have Flash file B
ro
MT6577___GT-I9060I__Samsung_GT-I9060I__4.4.4__I8552ZCAME1
The Following User Says Thank You to SOFTWARE.HELP For This Useful Post:
Old 06-20-2016, 22:18   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,206
Hello bro,
post cm2 full logs here
Old 06-21-2016, 05:09   #5 (permalink)
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 323
Hello bro,
Identify&ReadInfo
Chinese Miracle II  [MTK module] v 1.50
Operation : Check / Read Info [ v1.50 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E59481200179CAE6F19
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : 0x7E69EEF5939780398651B865C41665CC
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Old 06-22-2016, 18:05   #6 (permalink)
FaizanChauhaan's Avatar
Member: 2564757
Sonork: 100.1673410
Thanks Meter: 25
Reflash this phone.. And write nv...
Old 06-25-2016, 01:01   #7 (permalink)
Member: 2589323
Just repair IMEI your problem will be solved I was facing the same issue with some other phone just write the orignal imei written on phones back.
Sent from my iPhone using Tapatalk
Old 07-14-2016, 09:55   #8 (permalink)
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 323
Not working bro..plz help Me
Old 07-15-2016, 18:20   #9 (permalink)
Member: 2082450
Thanks Meter: 1,420
Hello.
Does this mobile get network signal.?
Btw,
Find a working fimware and flash it..
Old 07-15-2016, 18:57   #10 (permalink)
rafiq alraza's Avatar
Member: 1877938
Sonork: 100.1659358
Thanks Meter: 67
change nv database file and write working imei your problem will solve.
Old 07-15-2016, 18:59   #11 (permalink)
Member: 1877938
Sonork: 100.1659358
Thanks Meter: 67
BPLGUInfoCustomAppSrcP_MT6572_S00_MOLY_WR8_W1315_M D_WG_MP_V36_1_2g_n - Download - 4shared - faisal choudhry
write this db file and write working imei
Old 07-16-2016, 16:56   #12 (permalink)
Member: 1844204
Sonork: 100.1111172
Thanks Meter: 323
Originally Posted by rafiq alraza View Post
Not working this file flash now dead : Read File flash ok MMI CODE problem
Page generated in 0.40752 seconds with 7 queries
