02-27-2016, 08:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Htc 616h Dead after flash and show Dll image fail then i make backup with infinity dongle and make flash with my another running phone. But after flashing phone is dead. i try to flash with backup file but same result. i also try with following flash file HTC Desire 616h (OTA V3_DUG Asia Stock) HTC 616,616H Dual Asia WWE 4.2.2 [MT6592] But still phone is Dead any solution please.. here is the log Code: Card found : S/N : D196677B , v0129 Chinese Miracle II [MTK module] v 1.40 Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3180351F9 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3180351F9 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : htc ProdName : htc_asia_sea_wwe ProdModel : HTC Desire 616 dual sim Device : htc_v3_dug AndroidVer: 4.2.2 MTKxCPU : MT6592 MTKxPRJ : SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP [Read Ok] : preloader_wt98518.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : blinkfeed.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / wt98518 / EMMC FW Size : 1272 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\Desire 616\my phone\MT6592__htc__HTC_Desire_616_dual_sim__htc_v3_dug__4.2.2__SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP\ All done! Done! Elapsed: 00:05:34 Reconnect Power/Cable! Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1D75281E3 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1D75281E3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : htc ProdName : htc_asia_sea_wwe ProdModel : HTC Desire 616 dual sim Device : htc_v3_dug AndroidVer: 4.2.2 MTKxCPU : MT6592 MTKxPRJ : SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V21_P30_1_wg_n EXTRA : LCD [0] : hx8394a_hd720_dsi_vdo_tcl LCD [1] : hx8394a_hd720_dsi_vdo_truly LCD Res : 1280x720 TOUCH [0] : GT9XX CAM [0] : ov8858_mipi_raw CAM [1] : ov8858_mipi_raw_truly CAM [2] : nt99252_yuv CAM [3] : hi257_yuv MODEM : wingtech92_wet_jb9_hspa_wt_pa_sky77593_band18_v3_asia LOCALE : ar_SA hy_AM bg_BG hr_HR en_US et_EE cs_CZ da_DK fi_FI el_GR iw_IL nb_NO fa_IR pl_PL pt_BR ro_RO sr_RS sk_SK sl_SI ca_ES ms_MY hi_IN hu_HU de_DE en_GB es_ES es_US fr_FR in_ID kk_KZ lv_LV lt_LT it_IT nl_NL pt_PT ru_RU sv_SE th_TH uk_UA tr_TR vi_VN zh_CN zh_TW zh_HK Done! Elapsed: 00:00:09 Reconnect Power/Cable! Load File Bad file detected! Scatter Load Ok , BaseBand : MT6592 , Project : wt98518 , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1D75281E3 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1D75281E3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3564 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000000E3E00000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_wt98518.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : BLINKFEED Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:36 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : BLINKFEED Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:49 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:58 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6592 , Project : wt98518 , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1D75281E3 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1D75281E3 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3556 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_wt98518.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : BLINKFEED Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:37 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : BLINKFEED Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:52 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:56 Reconnect Power/Cable! |
02-27-2016, 13:48 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Battery level Low. Charge battery and try to switch ON. You can also try to flash with file present on support- MT6592__htc__HTC Desire 616 dual sim__htc_v3_dug__4.2.2__SW_G98518A2_V008_M10_HTC_V 3DUG_ASIA_MP by PBs, but version is different. Br. Infinity Box Support Team. |
02-27-2016, 15:52 | #3 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | bro same problem with me only solved problem factory file write this this file and post result . http://www.mediafire.com/download/2t...jamesjerss.zip |
02-28-2016, 08:51 | #4 (permalink) | ||
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Quote:
But same result phone still Dead Quote:
Sp flash tool error 8417 The Load scatter is Invalid | ||
02-28-2016, 09:18 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Make HW Test to check eMMC status. If everything is good, write other version firmware. Br. Infinity Box Support Team. |
