04-26-2018, 09:08 | #1 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2256267 Status: Offline Thanks Meter: 8 | problem flashing stream b1 msm8610 hello l found this problem in the phone stream b1 cpu msm8610 the firmware does not pass on the phone please see the info ,I hope you give me some solution for this case. thank you in advance info: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 0B5ED12B ID_BLOCK_I : 008110E1 ID_BLOCK_L : B84822DC7BE7EC1FC8BD57B887C2527A ID_BLOCK_L : 3548F6595AC575FE13E2B76C6689A7A4 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 20 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : misc.img Flashing : lsplash.img Flashing : driver.iso Flashing : NON-HLOS.bin Flashing : boot.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : system.img Flashing : userdata.img ProgStart : start 2280512, num 8 ProgFinish : Read back verify failed at sector -277575498,num sectors 2280512 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
04-27-2018, 13:59 | #5 (permalink) | |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
you can read or flash stream b1 without battery too just for info good luck in futur | |
The Following User Says Thank You to dadarko For This Useful Post: |
