03-17-2008, 08:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: lost city :-( Age: 41
Member: 152266 Status: Offline Thanks Meter: 329 | REPORT new modul Spreadtrum cpu I will test and post results here ..THNX infinty team for hard working today test it cect c1000 phone... pinout Rx:12 Tx:13 Gnd :14 I send it infinty supporter with backup eproom and operation logs http://rapidshare.com/files/10015405...oom___logs.rar wbr; MAHMUT1982 |
03-17-2008, 15:48 | #4 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 46
Member: 122869 Status: Offline Thanks Meter: 11 | Here is one more CECT Y767: COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:2F03:0009 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4B468A23.[KT81_BLT_PCB01_GPRS_MT6225_S00.KT81BLT-L8HV2_06-071011NEWSVA.BIN_C8C2F1F2].rpl identification#1 detection finished device-id: 4B468A23 identification#1 protocol ver: 04 ver. sw1: KT81_BLT_PCB01_GPRS_MT6225_S00.KT81BLT-L8HV2_06-071011NEWSVA.BIN ver. sw2: KT81BLT-L8HV2.06-071011NEWSVA, 0D0E3D37 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ..................... detect standard fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ..................... detect standard fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _4B468A23_KT81_BLT_PCB01_GPRS_MT6225_S00.KT81BLT-L8HV2_06-071011NEWSVA.BIN_C8C2F1F2_20080317-132745.B0X.bin Finished, time used: 64 sec Remove/Install battery now ! Readed fullflash:http://rapidshare.de/files/38854059/...17-141211.html |
03-17-2008, 23:13 | #9 (permalink) |
Member: 122869 Status: Offline Thanks Meter: 11 | I cant format thats all point why am I writing all this.Here is the log: COM1 [Serial0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:2F03:0009 Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25error: detection failed (26 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 26 sec Remove/Install battery now ! Am I doing something wrong????? |
03-18-2008, 23:26 | #11 (permalink) |
Member: 122869 Status: Offline Thanks Meter: 11 | Thank you The complete format is working good also repared IMEI after that withaut problem but the problem still same.I have 8 phones with same problem-cant erase mesages,photos,wideos....after atemt to erase the phone stays ay please wait motion and only removing batery from phone and turning on again can solve this. Can I use the readed flash from good phone to flash this phones??? ANY ADVICE Thanks again BR |
how can we use mc tool to spreadtrum cpu | unlock_solution | MC-Tool | 12 | 06-08-2008 03:59 |
help me infinty team SPREADTRUM cpu....? | SHOEB AHMED | Infinity-Box | 10 | 01-29-2008 13:27 |
c600 spreadtrum cpu | sukhdeep | Infinity-Box | 1 | 11-26-2007 19:26 |
is it support Spreadtrum cpu ? | black snake | Chinese Cocktail | 1 | 10-29-2007 12:39 |
ZT6618 with spreadtrum cpu | aria_mobile | Infinity-Box | 3 | 10-07-2007 19:33 |
