Old 03-03-2009, 02:08   #1 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
coral 200 after try to reset user code now phone is dead
i try to reset user on phone coral 200 from digicel now phone is dead
when i try to flash phone i get this error
i try with coral 200 file and with zte225 too
COM9 [VCP0] selected
module v1.63
Device: Coral-200
Checking data, wait...
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0098:0096
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-static_20090302-185701.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-security_20090302-185702.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-complete_20090302-185703.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
repair write error [00400000:0800]...
error: write failed[00400000]
Write Failed
Finished, time used: 38 sec
Remove/Install battery now !
Old 03-03-2009, 13:29   #2 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
Still wating for your help
Old 03-03-2009, 15:49   #3 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
still waiting for your advices no answer from you
Old 03-03-2009, 16:01   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
1. never try to flash phone if you need to remove user lock due to flashing can not remove user lock
2. now try to flash phone again (but select model BSNL-G200).
Old 03-03-2009, 18:04   #5 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
you dont understand my questions my friend first i use unlock user botton then phone become dead i know flash phone not remove the user code im not new in this bussiness
i flash phone cause phone was dead after user reset code
2. y try to flash the pone again selecting the model you told me but using the same coral200 firmware and get the same response here is log
module v1.63
Device: Digibee-BSNL-G200CF
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0098:0096
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090303-105916.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090303-105917.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090303-105918.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Write Failed
Finished, time used: 39 sec
by the way i notice that phone dont boot by power botton only but if i remove an put battery back
Old 03-03-2009, 23:37   #6 (permalink)
Member: 130995
Hello,
As I can understand this phone has new flash chip type, probably it's a reason why phone can not be flashed.
We need some time to check situation with this new flash type.
btw, do you have original full flash backup of this phone ?
Old 03-03-2009, 23:44   #7 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
no man i made the big mistake of work fone without backup i trust in box security since i havent face this kind of problems with your product
Old 03-04-2009, 23:34   #8 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
we read flash file from another phone here is link for download file, by the way i cannot write file back to phone
in file you will find eprom and full flash security and all back ups
http://rapidshare.com/files/205396511/coral.rar
The Following User Says Thank You to denisirias For This Useful Post:
Old 03-05-2009, 14:28   #9 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hi,
I can see two flash backup files (dated 28.02 and 04.03).
Did you read both from good working phones ?
Old 03-05-2009, 18:08   #10 (permalink)
Member: 130995
@denisirias
try to read full flash from your phone again, but select model LG KG370
send full flash backup to [email protected]
Also post here full texct from phone back label, I think that your phone is not "Coral-200" but probably it's more advanced version. f.e. something like "Coral-200FM" or something like this.
Old 03-06-2009, 10:22   #11 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
@denisirias
Imposible to read flash again phone is dead too this one was from another friend store who did what I did with mine now we have both phones dead and by the way phone we have are not solars like some we found on the Internet with same model name
Old 03-06-2009, 16:25   #12 (permalink)
Member: 130995
Hello,
What is exact text from phone back label ?
Old 07-21-2009, 19:34   #13 (permalink)
Member: 321874
Thanks Meter: 4
i have same problem after try to write firmware phone is dead
Old 07-21-2009, 19:39   #14 (permalink)
Member: 130995
Hello,
What was the error during flash write process ?
how to reset user code in zn 200 nilan Smart-Clip 1 03-24-2009 10:18
I560 dead after flash for reset user code. Amnarj UST Pro II 3 12-16-2008 04:38
I560 dead after flash for reset user code. Amnarj QUALCOMM Models (3G) 0 12-15-2008 16:36
After reset security code 2760 phone is dead sartaj HWK 2 10-24-2008 07:28
TDMA and CDMA phones - how to reset user code? UnlockBR Phoenix Black Box 0 11-10-2005 14:36
Page generated in 0.20244 seconds with 9 queries
