12-07-2008, 18:22 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Coral 200 "no service" after unlock after direct unlock coral 200 shows "no service" with all the sim cards (here in Pakistan 900/1800 freguincy works) ..........please check logs . COM13 [VCP0] selected module v1.57 Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: VDF-P108A2 U B07-FrEs-DG05 g3dBV2.0 Oct 10 2007 16 58 27 04.12.0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-static_20081205-013645.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-security_20081205-013646.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-complete_20081205-013647.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200_lock-area_20081205-013649.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 20 sec Remove/Install battery now ! |
12-07-2008, 20:12 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Are you sure that Coral-200 works in your network ? As I can see firmware in your phone has FrEs pack so it may be that this firmware is for American market with other band. |
12-08-2008, 12:19 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I am not sure but you have a reason to try. At first make full flash backup and send it to [email protected] (due to as I can see your phone has new firmware). Then flash phone with ZTE-225 files, f.e. this set: ZTE-225_Main_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007 ZTE-225_LP_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007_Bg Last edited by InfinitySupport; 12-08-2008 at 12:27. |
How to Repair "no service" after unlock KP 175? | SiriusV | VygisToolbox | 7 | 05-03-2010 05:07 |
coral 200 no network after unlock | GraveSlayer | Infinity-Box | 0 | 05-05-2009 06:36 |
Nec 606..."no Service" After Unlocking. | albarka network | Redbox | 3 | 09-14-2006 09:47 |
x660 "no service" after unlock!?! | sale | TST Dongle | 0 | 08-07-2006 18:32 |
help: try reset security code and "NO SERVICE" after | paullovinicius | n-Box | 9 | 09-15-2005 20:46 |
