04-26-2008, 09:55 | #1 (permalink) |
Insane Poster Join Date: Jan 2003 Location: Philippines Age: 47
Member: 19411 Status: Offline Thanks Meter: 1 | Coral 200 successfully unlock but no service... I successfully unlocked coral 200 by flashing this firmware: ZTE-225_Main_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007.B1M ZTE-225_LP_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007_Bg.B1P Here is the log: Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_ZTE-225, Vodafone-225_eeprom-sta_20080426-162747.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_ZTE-225, Vodafone-225_eeprom-sec_20080426-162749.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_ZTE-225, Vodafone-225_eeprom-complete_20080426-162756.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 44 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 -------------------------------------------- Unlock success but no service.... I forgot to check if it has a service before i unlock it..... when i try to call emergency call it shows "call not possible"... What should i do??? TIA |
04-26-2008, 22:27 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can flash phone with Corall-200 files and check is it possible to make 112 (emergency) call or not. |
Pantech PG C300 cingular successfully Unlock....But limited service | kerug | Infinity-Box | 14 | 10-09-2018 08:03 |
vodafone v810 successfully unlock but no service | SHOEB AHMED | Multi-Box | 1 | 12-15-2008 16:18 |
>>> Coral 200 successfully unlocked <<< | keaelite | Infinity-Box | 4 | 07-08-2008 07:49 |
