10-07-2009, 00:59 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Heaven Age: 41
Member: 613221 Status: Offline Thanks Meter: 26 | Coral 200fm dead after trying to unlock COM4 [VCP0] selected module v1.70 Device: Coral-200FM Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Coral-200FM_eeprom-static_20091006-175244.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Archivos de programa\InfinityBox\Pana01\Coral-200FM_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20091006-175245.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Archivos de programa\InfinityBox\Pana01\Coral-200FM_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20091006-175247.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware repair write error [00800000:0800]... error: write failed[00800000] Write Failed Finished, time used: 58 sec Remove/Install battery now ! When I tried to unlock it gave almost the same error. Also notice that now IMEI is damaged, so I supose EEPROM is damaged also. I made a full flash backup wich Is here Maybe it's usefull for something. Please help me in this. Phone is from Digicel Honduras. |
The Following User Says Thank You to franklin12004 For This Useful Post: |
10-07-2009, 09:45 | #3 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | re Quote:
10-07-2009, 13:36 | #4 (permalink) |
Member: 613221 Status: Offline Thanks Meter: 26 | it's not the IMEI I'm worried about right now, the most important thing for me right now is to make phone work. I'm going to try selecting huawei t201 like chagua said and I'll post results. Although right now the unlock is the least important now. |
11-25-2009, 17:06 | #8 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | the problem is coral200fm , coral 400fm, coral500fm got new flash chip that dont allow to write in it so phone become dead because it can restore security |
05-08-2010, 14:09 | #9 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 44
Member: 133351 Status: Offline Thanks Meter: 20 | COM3 [VCP2] selected module v1.78 Device: Coral-200FM Checking data, wait... Action: write flash write: Firmware Coral-200FM_VDF-P108A2FM(VBR)(G)(U)B07-FrEs-DG01_Oct-15-2008.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -DG-P108A2FM VBR G V1.0.0B04 Oct 15 2008 09.03.01 21.38.01 09.0 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200FM_eeprom-static_20100508-095944.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200FM_eeprom-security_20100508-095945.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Coral-200FM_eeprom-complete_20100508-095952.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware repair write error [00800000:0800]... error: write failed[00800000] Write Failed Finished, time used: 1 min 16 sec Remove/Install battery now ! |
W900i DEAD AFTER TRYING TO UNLOCK | erickxson | Cruiser Suite | 17 | 11-07-2006 18:10 |
W810i dead after trying to unlock.... | Burnt Cobba | Universalbox | 3 | 07-06-2006 20:07 |
e800 dead after trying to unlock with Agere Attack | flash | NSPRO | 1 | 05-05-2005 21:35 |
a55 dead after trying to unlock | jonzey | E-Gold Based Phones | 3 | 12-16-2003 22:52 |
T720 dead after trying to unlock with Motorola PATRIOT Clip | patric | Motorola P2k | 9 | 07-10-2003 17:20 |
