07-16-2010, 22:51 | #1 (permalink) |
Junior Member Join Date: Dec 2008 Location: panama
Member: 918421 Status: Offline Thanks Meter: 7 | coral 255 not suppott COM8 [VCP0] selected module v3.49 Device: Coral-255 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5970:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SFE-DIG8-P109A14V1_0_0B04.BIN project-id: SFE-DIG8-P109A14V1.0.0B04, 00000000 code offset: 00000000 ffs offset/size [02]: 006E0000/00120000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 006E0000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Coral-255_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SFE-DIG8-P109A14V1_0_0B04__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Coral-255_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SFE-DIG8-P109A14V1_0_0B04__ffs_20100716-161933.B0E.bin flash: 98009600000000:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ........................ required data found flash: 98009600000000:2AEA0000000000 flash: 98009600000000:2AEA0000000000 Write: area 1 (pass 1) ........ area 1 patch applied Ok Special operation Done ====> Write ... flash: 98009600000000:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 47 sec Remove/Install battery now ! Loading file v.02... Coral-255_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SFE-DIG8-P109A14V1_0_0B04__ffs_20100620-140858.B0E.bin loaded |
The Following User Says Thank You to miguel_luo For This Useful Post: |
11-01-2010, 03:57 | #3 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
11-04-2010, 00:37 | #4 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | Quote:
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
