Old 10-15-2008, 10:04   #1 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 500
coral-300 unlock done
COM5 [VCP3] selected
Device: Coral-300
Checking data, wait...
Action: unlock
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: EC22E000000000:70E59F00000000
flash: Samsung KAD060300B T 8Mb
Boot Done
Set baud...
230400
Set baud Done
Check flash...
current eeprom imei: 356624014339742
file saved: C:\Program Files\InfinityBox\AModule\eeprom_356624014339742_C oral-300_20081015-170253.98E.bin
Check flash Done
Check space...
file saved: C:\Program Files\InfinityBox\AModule\_eeprom-calibration_20081015-170301.98E.bin
file saved: C:\Program Files\InfinityBox\AModule\_eeprom-ffs_20081015-170332.98E.bin
reading[lock-area-2]...
file saved: C:\Program Files\InfinityBox\AModule\lock-area-2_Coral-300_20081015-170345.98E.bin
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write Done
Finished, time used: 89 sec
Remove/Install battery now !
The Following User Says Thank You to jakoy For This Useful Post:
Old 10-15-2008, 12:14   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 11-26-2008, 10:10   #3 (permalink)
Member: 3212
Thanks Meter: 8
Which cable is used for this phone?
Thanx in advance.
Old 11-26-2008, 18:48   #4 (permalink)
Member: 130995
Thanx in advance.
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout
Here is information how to build your own cable: http:///vbb/showthread.php?t=342807
Old 11-26-2008, 21:04   #5 (permalink)
Member: 3212
Thanks Meter: 8
All clear
Thanx for reply!
Regards
Lg cw-300 unlock done......... ^^^RAVI SOOD^^^ VygisToolbox 1 01-09-2010 06:12
Coral 300 Unlock alamgarh Infinity-Box 10 11-27-2009 12:20
coral 300 unlock via modify cable.. ken_jez Infinity-Box 1 12-06-2008 13:55
Coral 300 Unlocked Successfully elcapitel Infinity-Box 1 07-16-2008 14:41
error coral 300 unlocking sabbalde Infinity-Box 3 03-21-2008 17:22
Page generated in 0.28800 seconds with 8 queries
