coral 460 pinout. Anybody have pinout for coral 460? please i need it, tx rx gnd. Thanks |
hello! Which CPU is used in this phone? If you dont have pinfinder i can give you instructions how to find pinout on mt62xx CPU using multimeter |
How many pins ? Also, probably you have a reason to try automatic pinout detection. Actually it's not so hard as you can think: C:\InfinityBox\Documentation\PinFinder\Infinity-Box_PinFinder.pdf |
Did you tried to use the same cable/pinout as for Coral-330/440 ? :) |
hello! 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. |
I need to make the cable that connect my pin finder to the infinity box... Any diagram of doing it please. |
make the cable that connect my pin set one multimeter probe to some grounded phone part thanks.. |
please help with eeprom file coral 460 Quote:
Hello, What is this phone CPU chip name ? |
SFR 341 cable mt 6253 |
