01-16-2010, 00:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Coral 620 is reused be unlocked It will change the flash by Coral-620_CELLONSZ23_07A_PCB01_GPRS_MT6223_S00.C2082_2_5 _FM_US_DIGICEL_En_Fr_Es.B0M and continuing with the same problem, any suggestions??? [1] COM3 [VCP0] selected module v3.02 Device: Coral-620 Checking data, wait ... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs / eeprom backup enabled, it may takes several minutes! ====> Boot ... Press and HOLD Power button now! 19,200 fixed Connecting, wait ... Initializing [6223:8 A05: 8A00] ... CPU: MT6223 chip: 0011:3575:000 C status: FF boot packet size: 0400 Release Power button now! Boot Done ====> Initialize ... detecting chip # 00 in region # 00 ... flash: EC257E25062501: 2AEA0000000000 flash: AMD / Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip / regions detected: 01/01 Done Initialize ====> Baud September ... 921600 September baud Done Initialize ====> bootcode ... Bootcode Initialize Done ====> Check firmware integrity ... bootloader usb detect ... .. bootloader usb detect (phase # 2) ... .. usb bootloader (chip) is absent rom searching info ... rom info search finished rom info structure: 2nd [standard] generation TCL-ID is absent info rom detection finished ==================== New firmware detected (v.3.02, database date: 13.01.2010): CELLONSZ23_07A_PCB01_GPRS_MT6223_S00.C2082_2_6_FM_ EU_DIGICEL_AAC.BIN This firmware is missing in support area. If this phone is good and working: - Download latest software from support area and try again, probably this latest firmware already supported in software - Make "Read full flash" operation - Send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - Include in your e-mail full text from phone back label (phone name etc.). ==================== rom info see: 04 sw version: CELLONSZ23_07A_PCB01_GPRS_MT6223_S00.C2082_2_6_FM_ EU_DIGICEL_AAC.BIN project-id: C2082_2.6.FM.EU_DIGICEL_AAC, 00000000 offset code: 00000000 ffs offset / size [01]: 00700000/00100000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs / eeprom address assigned: 00700000 sec info (detailed) detection ... searching sec info # 1 ... . search info # 1 finished sec Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Coral-620_CELLONSZ23_07A_PCB01_GPRS_MT6223_S00.C2082_2_6 _FM_EU_DIGICEL_AAC__ffs ... file saved: C: \ Program Files \ InfinityBox \ MModule \ 620_CELLONSZ23_07A_PCB01_GPRS_MT6223_S00.C2082_2_6 _FM_EU_DIGICEL_AAC__ffs_20100114-Coral-171958.B0E.bin flash: EC257E25062501: 2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait ... detection procedure completed detection procedure, wait ... detection procedure completed Patch required data Done Special ====> operation ... detecting area parameters to apply patch 1 ... ................................ error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC257E25062501: 2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 57 sec Remove / Install battery now! |
The Following User Says Thank You to hvalero2001 For This Useful Post: |
01-16-2010, 02:19 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. Try to make unlock with "smart fast" unlock method 2. Code: ==================== New firmware detected (v.3.02, database date: 13.01.2010): CELLONSZ23_07A_PCB01_GPRS_MT6223_S00.C2082_2_6_FM_ EU_DIGICEL_AAC.BIN This firmware is missing in support area. If this phone is good and working: - Download latest software from support area and try again, probably this latest firmware already supported in software - Make "Read full flash" operation - Send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - Include in your e-mail full text from phone back label (phone name etc.). ==================== |
01-16-2010, 16:45 | #3 (permalink) |
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Thanks ... It worked ... here the log [1] As for the full flash I could not do, because as I said in my previous post had already flashed the cell, but here's the information the same [2 ].... If you still want the full flash, to speak to do so now. I'm sorry: ( [1] http://forum.gsmhosting.com/vbb/show...postcount=1624 [2] UTStarcom Model: C620 / 9 FCC ID: T38UF2082 IMEI: 357434024032419 S / N: 05EE30903284070 BAND: 900/1800 |
Coral 620 Digicel unlock error | unlockmoto | Infinity-Box | 5 | 12-13-2009 07:03 |
Coral 620 pinout | GuilleC_PMA | Infinity-Box | 12 | 12-13-2009 07:00 |
Coral 620. Convert and Unlock + Cable {MANUAL} | motursa | Infinity-Box | 4 | 11-25-2009 13:04 |
Coral 620 Can't Read Pinnout | Dimortal | Infinity-Box | 2 | 05-21-2009 19:11 |
Help not see Coral 620 in the module | GuilleC_PMA | Infinity-Box | 2 | 04-27-2009 20:06 |
