Old 01-04-2012, 08:55   #1 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Cordless Phone Model : FC 8050 Not unlocked
Here is log >
COM2 [VCP0] selected
module v4.13
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:67F1:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 7F227E220A2201:2BEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11.BIN
project-id: 08GE0_H_07_11, 00000000
code offset: 00000000
ffs offset/size [01]: 00380000/00080000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00380000
standard ffs/eeprom offset confirmed: 00380000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00380000-003FFFFF
firmware area: 00000000-0037FFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_0 7_11__ffs...
file saved: C:\InfinityBox\MModule\ATEL23_08A_BULGRIAN_PCB01_G SM_MT6223_S00.08GE0_H_07_11__ffs_20111228-124200.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 3 min 13 sec
Remove/Install battery now !
Phone says " OPERATOR LOCKED "
Support help !!!
Kotogsm
Old 01-04-2012, 17:25   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
make backup, try format FFS complete
Old 01-04-2012, 17:43   #3 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Smile
Hi
Thanks for fast answer .
After format FFS complete , no result " OPERATOR LOCKED "
Here log :
module v4.13
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\InfinityBox\MModule\mtel-nov\ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0 _H_07_11__ffs_20120104-183747.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 1 min 17 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 01-05-2012, 22:11   #4 (permalink)
Member: 148515
hello!
please post original backup we will check what is wrong is spare time
Old 01-06-2012, 12:42   #5 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Here is the flash ...
Link DOX.bg -
Thanks advance
Old 01-06-2012, 19:24   #6 (permalink)
Member: 148515
hello!
thank you, downloaded!
Old 01-07-2012, 00:11   #7 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Smile
Ok ...
I waiting for answer .
Thanks advance .
Kotogsm™
Old 01-30-2012, 16:10   #8 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Still waiting ...
Kotogsm
Old 01-30-2012, 22:04   #9 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Please, try to keep this phone on hands 1-2 more days, we will try to release updated software.
Old 02-11-2012, 19:08   #10 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Wait !
Phone connected .. ready for test .
Kotogsm
Old 02-21-2012, 20:32   #11 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
No success with new update . support help .give me instruction .
Old 02-22-2012, 10:27   #12 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, send operation log text for unlock operation to [email protected]
Also, do you know locked operator MCC/MNC ?
Old 02-22-2012, 13:26   #13 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
Send mail .
Kotogsm
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.24157 seconds with 9 queries
