01-15-2009, 09:07 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Cosun 6659 this is the log pinfinder software version: 1.17 cable type: 1x8 (L8A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM8... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6219 result: Rx:2 Tx:3 time required: 4 sec Power On ! this is the log complete formated ==== log: [1/15/2009 2:09:54 PM] ==== COM8 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8A01]... CPU: MT6219 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! this is log imei change COM8 [VCP0] selected module v2.73 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 352993010120319 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8A01]... CPU: MT6219 high speed boot On Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219,E01 Date: 2004.06.18 Version: 1.9.1.0 Version: T560.07.13.V13 Version: E01_HW detecting structure #2... done 58 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... done 58 byte(s) read verification... verification done: 35299301012031 Finished, time used: 12 sec Remove/Install battery now ! thx to infinity team for your hard work regards notgood |
Cosun 6655 | wsw243 | Infinity-Box | 1 | 04-11-2008 18:33 |
Cosun 8266 success | rajumobile | Infinity-Box | 1 | 11-22-2007 17:51 |
about cosun cs512 | shailesh_chauha | Chinese Cocktail | 4 | 10-18-2007 13:35 |
nokia cosun testpoint | matrix123 | Infinity-Box | 1 | 09-04-2007 15:29 |
14 May 2007: "Good morning, Aruba !": Cosun 289, Asus V75 models supported... | InfinitySupport | Infinity-Box | 15 | 05-17-2007 02:31 |
