02-07-2009, 08:49 | #1 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 319021 Status: Offline Thanks Meter: 1 | couldnt format ffs Alcatel S621 module v2.64 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2A03:A004 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D374B A26.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_209A49A0].rpl identification#1 detection finished device-id: D374BA26 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 5FB665DF ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002004312 flash: 01227E22422200:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22422200:18E59F00000000 error: error# 0000006F error: flash erase error: 01FA0000 Finalization Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_D374BA26_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_209A49A0_20090207-123714.B0X.bin Finished, time used: 221 sec Remove/Install battery now ! Always error: 01FA0000 |
02-07-2009, 08:53 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What is your phone history ? If flash/format operation always stop at the same flash address it may be hardware fault (f.e. bad soldered or damaged flash chip). |
02-07-2009, 10:58 | #3 (permalink) |
Member: 319021 Status: Offline Thanks Meter: 1 | No. Phone is not soldered or damaged. Phone is new and always show logo when power on. I am wrote full flash from support and ok. I have 3 such phones, and all with such problem when making format ffs |
02-08-2009, 15:57 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If flash/format operation always stop at the same flash address it may be hardware fault (f.e. bad soldered or damaged flash chip). Did you checked phone hardware ? |
02-08-2009, 18:19 | #11 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | i got fone with same problem a few days ago i unlockedusing simfree flash the customer says he put some thing through bluetooth nd then phone stop on alcatel freez nd then i formate in complete mode then same again freez then i formate in safe mode same again freez after oll i formate in complete mode nd fone start ok but now fone stuck on alcatel i flashed with simfree flashing and fone is gone dead format is not working giving me error flash error retry plz infinity team give a repair flash file for alcatel ot-s621x thnx br yasermalik |
02-08-2009, 20:03 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @rafauz Do you understand what you talk about ? Why you continue to ignore my advices and continue to talk about eeprom files ? Why you can not understand that if flash chip can not be erased this means that this flash chip can not be written too and in most cases it is HARDWARE problem but not software problem ? If flash/format operation always stop at the same flash address it may be hardware fault (f.e. bad soldered or damaged flash chip). boys... if you have zero knowledge I strongly suggest you to read advices that was given to you by mega extra super very high qualified person who have more than 10 (ten) years of experience in mobile phones repair. Do you understand what is 10 (ten) years ? I am sure that 10 (ten) value even bigger than your age if you continue to ignore repeated advices that was given to you by professional person. |
02-09-2009, 07:37 | #15 (permalink) | ||
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
alcatel s621 hang on alcatel | mobile_sos | Infinity-Box | 5 | 03-24-2010 10:06 |
Sucsessfully unlock alcatel S621 !!! | reaz.com | Infinity-Box | 28 | 01-21-2010 00:48 |
alcatel s621 help | mobilna klinika | Easy-Unlocker | 1 | 02-10-2009 16:32 |
alcatel s621 unlock flash need | G$M solution | Infinity-Box | 5 | 02-05-2009 16:05 |
Alcatel Ot-c701 Format Ffs | Parminder Singh | Alcatel TCL Hardware Repair | 4 | 08-09-2008 18:31 |
