12-14-2010, 19:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | cpu 6253n arm not detect i like to disable calibrate touchscren OM17 [VCP0] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not boot device: 03E8:S_STOP error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 19 sec Remove/Install battery now ! what problem is please help me thank you allll |
12-17-2010, 10:28 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Try with other option like select 6253 Nor/6228-6253 Nand option from Model tab in Chinese Miracle and then try. Wr. |
02-19-2011, 17:36 | #3 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | another 6253n not detect what problem is????????????? COM17 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not boot device: 03E8:S_STOP error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 1 min 2 sec Remove/Install battery now ! |
02-19-2011, 22:03 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! did you try both format methods? safe and complete? Last edited by InfinityHelp; 02-19-2011 at 22:10. |
02-20-2011, 22:08 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! does phone actually ask for Touchscreen calibration? Can't you make it manually, buy tapping test points by Pen? |
02-21-2011, 21:53 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! Can't you make it manually, buy tapping test points by Pen? skipping touchscreen is inly useful when you have full hardware keys set. does your phone have? |
09-07-2011, 12:53 | #11 (permalink) | |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Quote:
after long temp and after more update suported or not | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
