Old 09-21-2010, 21:24   #1 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
CPU: MT346C not supported yetMT346C
software version: 1.20
cable type: 1x5 (L5A)
platform: MT: MT62xx (autodetect)
searching adapter at COM3...
adapter found, version: 2000
pins: 5, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT346C
result: Rx:4 Tx:2
time required: 7 sec
Trying to Power-On...
Power On !
saved: ht-g20
COM3 [VCP0] selected
module v3.22
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [346C:0001]...
CPU: MT346C
high speed boot Off
error: hardware is not supported: [0000346C:00000001]
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 7 sec
Remove/Install battery now ! hope give new update
Old 09-21-2010, 23:10   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
this is new CPU type MT6253
you can read out flash selecting NAND CPU type.
IMEI change is supported, format FFS and flash write- not
we are working under this problem, support will be released soon
Old 09-22-2010, 08:50   #3 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
hello!
pins: 5, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
CPU: MT346C
result: Rx:4 Tx:2
COM3 selected
module v3.22
Device: Autodetect 6228-6239 NAND
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
interesting cpu type found: 6253:8A02:8A00
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
detect custom parameters...
detect project-id...
project-id: X19_HT_B_SS_MLA_06S0804
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_SS_MLA _06S0804.BIN_FLNK5N2866ATD_BQ12
project-id: X19_HT_B_SS_MLA_06S0804, 00000000
code offset: 00000000
ffs offset/size [02]: 00F00000/00100000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.22, database date: 02.09.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 15Mb
number of areas/bytes to read: 1:00F00000
file saved: C:\Documents and Settings\RUBY\My Documents\RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_H T_B_SS_MLA_06S0804.BIN_FLNK5N2866ATD_BQ12__firmwar e_20100922-144212.B0M.bin
Disconnect...
done
Finished, time used: 8 min 0 sec
COM3 selected
module v3.22
Action: reset settings ("format ffs")
Model: Autodetect 6228-6239 NAND
19200 autodetect
CPU: MT346C
high speed boot On
Can not initialize test mode, possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method
error: operation failed !
Finished, time used: 4 sec
Remove/Install battery now !can not format,,,thank for ur support ,we are waitting mode
Old 09-22-2010, 21:21   #4 (permalink)
Member: 148515
hello!
please send this fimrware to [email protected], if it is not big problem for you
Old 10-23-2010, 23:53   #5 (permalink)
Member: 1043909
Thanks Meter: 60,926
We are waiting for test reports and comments here: http://forum.gsmhosting.com/vbb/f425...ments-1123803/
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 1.20179 seconds with 9 queries
