Old 11-04-2008, 13:25   #1 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
Is CPU MT6223 supported bye your tool ?
==== log opened: [04/11/2008 11:30:53] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe
Loading data, wait...
[Infinity Box] v2.63
S/N: 2BAC:0111
Wait...
Device: Autodetect 6205-6227 NOR
Done
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [04/11/2008 11:31:06] ====
COM3 [VCP0] selected
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6223:8A05]...
CPU: MT6223
high speed boot enabled
chip: 0011:B446:000C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2BEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: SIMCOM23_08A_PCB01_GPRS_MT6223P_S00.F2302_FOREIGN_V1_00.BIN
ver. sw2: F2302_foreign_V1.00, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E90000
Detected eeprom/ffs address is non-standard: 00E90000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E90000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00170000
ffs chip: 00
eeprom/ffs area: 00000000:00E90000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[SIMCOM23_08A_PCB01_GPRS_MT6223P_S00.F2302_FOREIGN_V1_00.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[SIMCOM23_08A_PCB01_GPRS_MT6223P_S00.F2302_FOREIGN_V1_00.BIN]_20081104-113430.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 204 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== log: [04/11/2008 11:35:33] ====
Action: imei
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono-CPU
new imei: 350448011558555
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6223
Connecting, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: F2302_foreign_V1.00
Version: F230_REV1.5
detecting structure #2...
 1 2 3 5 7 8 9 11 13 15 16 17 19 21 22 23 25 27error: detection failed (18 tries), read flash and send to support
connection Ok
error: can't read required data
error: operation failed !
Finished, time used: 30 sec
Imei 35044801155855 already was repaired: 04/11/2008-11:36:08
Continue with this imei ?
==== log: [04/11/2008 11:36:30] ====
Action: "repair imei"
imei write method: mode-3
Boot...
19200 fixed
Connecting, wait...
CPU: MT6223
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
detecting security area (code #2)...
security area (code #2) is absent
eeprom/ffs found near: 00E60000
Detected eeprom/ffs address is non-standard: 00E60000
Posible reasons:
autodetected eeprom/ffs address[00E60000] confirmed by user
eeprom/ffs size: 001A0000
ffs chip: 00
eeprom/ffs area: 00000000:00E60000-00FFFFFF
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[SIMCOM23_08A_PCB01_GPRS_MT6223P_S00.F2302_FOREIGN_V1_00.BIN]_20081104-114017.B0E.bin
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "repair imei" procedure again
If imei can't be detected:
1. make "complete" ffs format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "repair imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 237 sec
Imei 35044801155855 already was repaired: 04/11/2008-11:40:31
==== log: [04/11/2008 11:40:43] ====
Action: imei
19200 autodetect
CPU: MT6223
Connecting, wait...
Date: 2000.00.00
Version: 1.0
 1 2 3 5 7warning: wrong packet cs
connection Ok
Finished, time used: 10 sec
==== log: [04/11/2008 11:41:08] ====
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
CPU: MT6223
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Posible reasons:
ffs chip: 00
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Finished, time used: 69 sec
Action: read information
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6223, E05
Hardware version: F230_REV1.5
Software version: F2302_foreign_V1.00"
Software date: 2000.00.00
Barcode: MT012345678901234567
imei: 135790246811220
Finished, time used: 11 sec
Power off phone now !
Use only for mode-3 !
Imei 35044801155855 already was repaired: 04/11/2008-11:40:58
==== log: [04/11/2008 11:42:59] ====
imei write channel: imei #2 for dual sim/mono-CPU
Boot...
19200 fixed
Connecting, wait...
CPU: MT6223
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Posible reasons:
ffs chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[SIMCOM23_08A_PCB01_GPRS_MT6223P_S00.F2302_FOREIGN_V1_00.BIN]_20081104-114623.B0E.bin
What to do:
1. Power-On phone
2. wait 20-30 sec
2. Power-On phone
3. wait 20-30 sec
Finished, time used: 205 sec
all the operation and imei is 123..... so any help for this problem ?
wbr
Old 11-04-2008, 14:32   #2 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Dear bro, i think this CPU is supported by Infinity. May be you have some other problem..
Old 11-04-2008, 15:49   #3 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
Well CPU MT6223 is Supported from Long time Back
http://forum.gsmhosting.com/vbb/showthread.php?t=579117
http://forum.gsmhosting.com/vbb/show...highlight=6223
Use Search Button, U will Find Many More Examples.
for IMEI repair Problem,
What to do:
1. Power-On phone
2. wait 20-30 sec
2. Power-On phone
3. wait 20-30 sec
If imei can't be detected: read flash and send to support: mt62xx @ gmail.com
Regards
Shubhanshu
Old 11-04-2008, 23:04   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, if all methods did not work for you- please follow this advice step by step:
1. Power-On phone
2. wait 20-30 sec
2. Power-On phone
3. wait 20-30 sec
belive me, this is written not for fun.
even if it looks hard, this must be done to get result
is CPU MT6129 supported or not? summer_20xx Infinity-Box 1 09-30-2009 13:17
does not work with any cpu MT6223 cellcarcol CPF-Dongle 8 09-23-2009 05:54
spreadrum cpu not supported in mc tool gs cell MC-Tool 3 10-02-2008 16:41
hello infinity team... is cect c828 supported? cpu type is mtk 6223 jaburnok Infinity-Box 2 06-28-2008 11:53
Page generated in 0.24157 seconds with 10 queries
