Old 10-20-2009, 23:07   #1 (permalink)
Member: 407810
Thanks Meter: 18
com port infinity IMEI change problem for CPU MT6225 ferrari phone new medium size
I have problem with new medium size ferrari phone and need to chnge the imei number as it start with 13555xxxx and this kind of imei number does not work with o2 and vodafone uk,
i try all the codes here and there is no code to enable com port for me as i can`t change the imei number via infinity if comport is not activated.
Please some one give some advise.
does spiderman box can change the imei without original usb cable?
I now phone is :CPU MT6225 as when i connect it to pc as a webcam it comes CPU MT6225 first and then install it automaticly.
help pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.
phone take nokia small pin charger and on the side it take usb cable and port looks similar to d800 samsung
Old 10-21-2009, 06:45   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
did u try to write imei with mode 2 or 3????what cable r u using with infinity
Old 10-21-2009, 10:58   #3 (permalink)
Member: 407810
Thanks Meter: 18
I use the original cable , comes with the phone.
do i need special cable for mode 2 or mode 3?
Thank you for your help in advance
Old 10-21-2009, 14:52   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
need to use rj45 cable.open phone and check for testpoints marked as rx tx ???
Old 10-21-2009, 16:58   #5 (permalink)
Member: 407810
Thanks Meter: 18
Can you explain more,
do i need to use the test point rj45 cable to change the imei?
i have 70 Pcs of this phones it will be big problem to do them this way.
also do you know if the spider man machine can do this more easy than infinity as i have the infinity and will buy the spider man if it can do the job quick.
Thank you,
Regards
Old 10-22-2009, 08:07   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Thank you,
Regards
find pinouts with spiderman.define pins.now open chinese miracle software and select comport used by spiderman.now u can perform any operation u want
Old 10-22-2009, 17:33   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
first of you must assemble com port cable.
with a help of it you will be able to use all IMEI changing methods. (1,2,3)
new 6225 cables do not have internal usb<>com port convertor.
those are regular USB cables, which is not usable for IMEI change with any of methods.
what is your phone connector type?
I am sure, with my help, you can assemble cable much more faster than waiting for pinout finding box.
Old 10-22-2009, 20:42   #8 (permalink)
Member: 407810
Thanks Meter: 18
hello!
Hi, Thank you for your help. i just bought new infinity box to do this phones.
i did many of this phones like ferrari and n97 and iphone(chinees) before but this new phones they wont give me option for comport when i connect them via usb cable wich comes with the phone.
here is picture for new ferrari. i have 60 Pcs of them, thank you in advance.
Old 10-22-2009, 23:06   #9 (permalink)
Member: 407810
Thanks Meter: 18
Cable looks like D900 Samsung.
Thank you
Old 10-23-2009, 23:08   #10 (permalink)
Member: 148515
hello!
power on phone
take multimeter
set it to "V" (voltage measuring)
one multimeter probe put to some grounded phone part.
connector shield is also OK.
with another proble touch one by one each connector pin.
check each pin voltage.
when you see voltage between 2,7...2,9- those are Tx/Rx
find them and we will continue with instructions of assembling own cable
Old 10-24-2009, 11:36   #11 (permalink)
Member: 407810
Thanks Meter: 18
Hi,
Thank you for all your help.
i just bought the infnity pin finder and is on the way.
as i have 5 different model of this phones with different cables so it was better to buy pinfinder to make the jub faster.
as much as i know with the pinfinder cables i don`t need to modify cable for this phone, is this correct?
Once again Thank you.
best Regards,
Saeed
The Following User Says Thank You to saeedhex1 For This Useful Post:
Old 10-25-2009, 00:09   #12 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 309
Yes pinfinder its the best way.
You no need modify anithing only conect,detect pinouts and enjoy.
Old 10-26-2009, 16:08   #13 (permalink)
Member: 148515
Hi,
best Regards,
Saeed
hello!
yes, using pinfinder you dont have modify cables.
sometimes phones dont keep tx/rx in system connector.
only in this case you must disassemble phone and search for test points on PCB. by my own experience- this is happening in 5%-10% of cases
Old 10-26-2009, 16:22   #14 (permalink)
ozeracar's Avatar
Member: 32738
Thanks Meter: 32
my friend you must use only rj45 cable or pinfinder , not usb. infinity imei inside firmware sections
so format and ok
Old 10-26-2009, 22:48   #15 (permalink)
Member: 407810
Thanks Meter: 18
so format and ok
Thank you, I`m waiting for my pin finder to arive. can you explain what do you mean by : infinity imei inside firmware sections so format and ok
Thank you
21/10/2008 new big samsung update all samsung 3g direct imei change added for freee samigsm78 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 40 12-05-2010 23:03
com port infinity IMEI change problem for CPU MT6225 ferrari phone new medium size saeedhex1 Chinese Models & Cloned Phones 0 10-20-2009 23:19
21/10/2008 new big samsung update all samsung 3g direct imei change added for freee tito millo Service Products News & Updates 0 10-21-2008 23:20
After imei change on T29 can't flash the phone roniri Old Ericsson Phones & Sony Phones 1 09-06-2002 00:12
Page generated in 0.22955 seconds with 9 queries
