03-16-2011, 12:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | cpu6253 format problem COM5 selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_UNSUPPORTED_DEV_ID flash id: 00EC:225500000000 NOR_UNKNOWN NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 37 sec Remove/Install battery now ! |
03-16-2011, 16:24 | #4 (permalink) |
No Life Poster Join Date: Jul 2008 Location: pakistan hafizabad
Member: 811013 Status: Offline Sonork: 03468717163 Thanks Meter: 744 | error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUNd select NAND and cpu 6253 and format ime chang 100 ok |
03-17-2011, 06:02 | #8 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | by selecting the 6228-6253 nand option , i get the same error. COM5 selected module v3.27 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_UNSUPPORTED_DEV_ID flash id: 00EC:225500000000 NOR_UNKNOWN NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 43 sec Remove/Install battery now ! any solution to this problem . |
03-17-2011, 08:07 | #9 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Look at the log posted by you- NOR flash chip: S_DA_NOR_UNSUPPORTED_DEV_ID flash id: 00EC:225500000000 NOR_UNKNOWN should be something like this- NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb Heat flash a little bit and then try again. Wr. | |
04-02-2011, 15:31 | #10 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 754208 Status: Offline Thanks Meter: 67 | Heat??/ r u crazy Quote:
06-08-2011, 15:25 | #12 (permalink) |
Member: 754208 Status: Offline Thanks Meter: 67 | If any problem Contact me on yahoo ([email protected]) or Facebook same id of yahoo |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
