credits detected unlock error please help me Card found: S/N : DEC48076 , v0122 Registered to: talk2more Connect phone on selected interface... Card serial: DEC48076 Card type: BEST Dongle Card password: QWPJtopi Link to my account: http://user.infinity-box.com Login: simlumia192 Connecting to server... Credits: 224 Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === NCSD Version : 5.1 Sw Version : 02177.00000.15184.36016 IMEI : 357816067317964 ProductCode : 059X0B8 ProductCodeB : 059X4F9 ProductSN : BF57A88AU Module Code : 0206634 === HW info === Public ID : 7B882A70197036FBBC00215E750F6A6D11B04C57 HW Version : 2140 BT Addr. : 300D4352B15D Wlan Mac : 300D438283C0 Battery Level : 2 % === Branding and security info === Operator : ATT-US SimLock : Locked! SimLock : 3101700000000 Country : United States of America Operator : AT&T Branding : RM-1073_1004 Sec. Mode : Restricted Done! Phone require ENO for enter in TEST mode!!! You can download ENO file in NaviManager tab! Phone require ENO for enter in TEST mode!!! You can download ENO file in NaviManager tab! Wrong data! Check if your PC is correct! Can't find product folder, seems as not set Set Product Path first! [ Settings -> DataPackage Path ] Can't find product folder, seems as not set Set Product Path first! [ Settings -> DataPackage Path ] SSChannel : Create SC SSChannel : SC Created! Selected ENO package download for RM-1073 SSChannel : DC Ok with code 0x02 Done! [WP8x] : Init TesMode [TSTM] : Use File : RM1073_2179.0000.9651.15153.207.760_enosw-wim-signed_858223.secwim === Base Phone Info Sw Version : 02177.00000.15184.36016 IMEI : ProductCode : 059X0B8 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.37 Protocol Implementation : 2.60 === Phone Initial info : Phone Model ID : Nokia.MSM8926.P6204_ATT.1.1 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 831BE6B18E7006372069545885A80F786C33D064 === Other info : SD present : False SECWIM : RM1073_2179.0000.9651.15153.207.760_enosw-wim-signed_858223.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SX4 Failed, will retry Auth again ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SDAuth not done! Try make SX4 after 1-2 minute and make "Unlock" again! Error! Check previous error message for more info! SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected Error while operation, check previous message for more info Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SX4 Failed, will retry Auth again ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SDAuth not done! Try make SX4 after 1-2 minute and make "Unlock" again! Error! Check previous error message for more info! Check SimLock info Conf key : 8000000000000000 Provider key : 3101700000000000 Country : United States of America Operator : AT&T Counters : Key 0 [3] , Fbus 0 [10] Blocks : 6 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close BLK : 3 Lock1:Close BLK : 4 Lock1:Close BLK : 5 Lock1:Close BLK : 6 Lock1:Close ============================= LOCKS : Closed ============================= Done! Link to my account: http://user.infinity-box.com Login: simlumia192 Connecting to server... Credits: 168 SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected Error while operation, check previous message for more info |
