05-04-2011, 11:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | eeprom needed SkyLine i6 pro i flash it with it's original flash from support: MAGCOMM23C_09A_PCB01_GPRS_MT6223P_S00.F96Z08SKYV01 _01B03_2010-10-28__Skyline- nd i think this phone needs good eeprom here is the log: COM121 [Serial2] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9084:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 00D144811079054A012133F1A5F8E1E7501E2200C8AC9408 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:00814400000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:00814400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:00814400000000 Finalization Done Finished, time used: 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! smart-card: disconnected smart-card: connected Loading file v.05... MAGCOMM23C_09A_PCB01_GPRS_MT6223P_S00.F96Z08SKYV01 _01B03_2010-10-28__Skyline-i6pro_16m_En_Fr_Ar.B0M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: MAGCOMM23C_09A_PCB01_GPRS_MT6223P_S00.F96Z08SKYV01 _01B03.BIN project-id: F96Z08SKYv01.01b03, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2010-10-28 13-44 hw1: MAGCOMM23C_09A_HW hw2: 09AW0936MP_SLIM_MAGCOMM23C_09A ==== [5/3/2011 8:05:41 PM] ==== COM121 [Serial2] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware MAGCOMM23C_09A_PCB01_GPRS_MT6223P_S00.F96Z08SKYV01 _01B03_2010-10-28__Skyline-i6pro_16m_En_Fr_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9084:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:00814400000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98000300000001:00814400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 8 min 25 sec Remove/Install battery now ! |
05-07-2011, 11:29 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | If even after full flash set is not alive then it could be hardware problem. See the flashing log- warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) Wr. |
05-07-2011, 21:28 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! how did you pick up flash file? only by model name? can you disassemble phone and check short version code? this can help to find needed flash file version. here is example: http://forum.gsmhosting.com/vbb/f425...phone-1166957/ |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
