02-01-2019, 15:43 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 809650 Status: Offline Thanks Meter: 24 | Cro-u00 frp failed cm2 v2.4 Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Huawei : Y3_Y5 [ CRO-L2x U00 ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_L23.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! TRIED WITH VOLUMES KEY COMBINATIONS AND CHANGE BOOT BUT FAILED |
02-01-2019, 18:39 | #6 (permalink) |
Member: 809650 Status: Offline Thanks Meter: 24 | Operation : Identify [ v2.04 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Huawei : Y3_Y5 [ CRO-L2x U00 ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_U00.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
02-01-2019, 18:41 | #8 (permalink) |
Member: 809650 Status: Offline Thanks Meter: 24 | with boot keys Operation : Identify [ v2.04 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM33) MODE : BOOTROM PORT : 33 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : Huawei : Y3_Y5 [ CRO-L2x U00 ] | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_U00.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
02-01-2019, 19:02 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | if you have time i will send you DA for test in PM i think team have add DA loader for BROM mode and you can test it with pressing volume down key Last edited by rebainoor; 02-01-2019 at 19:08. |
