06-28-2009, 07:38 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | sir, this is my first chinese phone, so i dont have any idea how to use cable (is there any cable to cyfon in cable pack with box) or I must buy a new cable for this phone ? in infinity option I have only cyfon 800? so how i connect this power off phone with infinity? |
06-28-2009, 21:57 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all you must assemble cable. for this- you must find pinout. you can search in infinity pinout folder as well as in this forum. if you will not able to find it- i can teach how to find pinout using multimeter |
06-29-2009, 21:21 | #5 (permalink) | |
Member: 477842 Status: Offline Thanks Meter: 80 | Quote:
CPU MT6225. so, how you teach me how to find pinout using multimeter ? | |
06-30-2009, 12:14 | #7 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | In phone I see CPU ARM MT6225A MT6318A SAMSUNG 816 So this phone have 2 CPU and 1 flash SAMSUNG ? As I see I have Connector 2x6 mini I found Samsung cable from infinity cables pack, model AT301 E760. An this is connector for this phone. But what about pinout ? how do I change RJ45 to connect phone to infinity ? |
07-02-2009, 15:42 | #10 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | Mam Złącze 2x6 mini 1. 887 2. GND 3. 592 5. 1029 6. 675 7. 805 9. 399 11,1024 Parametr ten pokazuje mi Multimetr kiedy zmiana Buzzer (biper) Tak, jak będę wiedzieć, jakie są złagodzić ciężar tx i rx na RJ45 ?? |
07-02-2009, 15:42 | #11 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | I have Connector 2x6 mini 1. 887 2. GND 3. 592 5. 1029 6. 675 7. 805 9. 399 11.1024 This parametr shows me multimeter when I change to Buzzer (biper) So, How I will know what are the specific weight alleviate tx and rx at the RJ45 |
07-03-2009, 21:38 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring (not Buzzer!!!). 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
Sabrent SBT-USC6K Hi-Speed USB 2.0 to Serial (9-pin) DB-9 RS-232 Adapter Cable (BLACK | IPMART | ipmart WebShop | 0 | 06-25-2009 07:30 |
Hi-speed USB Hub with 4 Ports | IPMART | ipmart WebShop | 0 | 12-10-2008 07:25 |
I need code for becker hi speed | synapserm76 | CAR Electronics | 1 | 10-11-2008 16:05 |
DirectCOM UFSx Hi-Speed Serial Communicator | SuPeR_PoPeY | Main Sales Section | 0 | 07-09-2005 16:02 |
Hi-Speed on USB? | Keni | Siemens-Benq RingTones and WallPapers | 2 | 11-09-2004 19:09 |
