03-20-2009, 11:04 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: BANGLADESH
Member: 684506 Status: Offline Thanks Meter: 46 | D-mobile sp unlock sucessfully done by Infinity-Box COM4 [VCP0] selected module v2.78 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 flash: 01227E22022201:29EA0000000000 checking area [00000000]: 00000000-007FFFFF... ffs/eeprom found near: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF detecting ffs/eeprom structure pass 1... ........... detect standard fat location pass #1... ............................ detect extended fat location pass #1... .......................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22022201:29EA0000000000 Backup required data Done Patch required data ... .......................... lock area found Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E22022201:29EA0000000000 flash: 01227E22022201:29EA0000000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 134 sec Remove/Install battery now ! thank's for Infinity team |
The Following User Says Thank You to s@zol For This Useful Post: |
Successfully unlocked/repaired phones by Infinity-Box | Infinity-Box | Infinity-Box | 76098 | Today 12:49 |
sony ericsson t303 unlock done by infinity box | zinoubinabil | Infinity-Box | 18 | 11-23-2011 13:08 |
c261 no power done by infinity box format only | pogs1962 | Motorola Old Legacy (EMMI) | 0 | 12-08-2009 03:57 |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 1 | 09-28-2009 17:24 |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
