10-20-2008, 06:26 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Philippines
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | D736 ( Bird ) sucess uNLocked Device: Bird-D736 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:9A04:740C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F7A67 F22.[MZ2006B1_AUSTRALIA_PCB01_GPRS_MT6227_S01.V1_00_03_ M070717AU0-V21.BIN_93AC757A].rpl identification#1 detection finished device-id: F7A67F22 identification#1 protocol ver: 04 ver. sw1: MZ2006B1_AUSTRALIA_PCB01_GPRS_MT6227_S01.V1_00_03_ M070717AU0-V21.BIN ver. sw2: V1.00.03_M070717AU0-V21, 858A536C ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000001:29EA0000000000 Backup required data Done Patch required data... ........................................... lock area found Patch required data Done Special operation... detecting additional parameters... .................................................. .............. error: additional parameters detection failed Special operation Done Write... flash: 98004900000001:29EA0000000000 flash: 98004900000001:29EA0000000000 Write: lock-area-1 Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_F7A67F22_MZ2006B1_AUSTRALIA_PCB01_GPRS_MT6227_S 01.V1_00_03_M070717AU0-V21.BIN_93AC757A_20081020-130659.B0X.bin Finished, time used: 47 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to FMC_GSM For This Useful Post: |
10-20-2008, 09:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Sucessfully unlocked phones by JAF No Tp Unlocker by Cinek | cellcarekphb | JAF No Tp Unlocker by Cinek | 187 | 04-07-2010 07:11 |
bb8120 unlocking sucessfully unlocked | bittubansal | FuriousGold | 2 | 01-28-2009 08:50 |
Ku990 sucessfully unlock by easy unlocker | rajan nishchal | Easy-Unlocker | 1 | 12-05-2008 08:50 |
Sucessfully unlock Bird-D736 with Infinity | Masud-GSM | Infinity-Box | 2 | 10-22-2008 16:07 |
E-65 Rm-208 Unlock Sucessful Unlock With Jaf Vspec | div_raj | J.A.F. V-SPEC | 1 | 03-12-2008 22:43 |
