Old 09-05-2018, 13:47   #1 (permalink)
Member: 2812901
Thanks Meter: 493
da file
i need note 5 frp da
Old 09-05-2018, 13:50   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
what do you mean note 5 frp da ?
what model brand name ?
did you try in cm2 ? if yes where is logs ? if not try and post logs
Old 09-05-2018, 13:58   #3 (permalink)
Member: 2812901
Thanks Meter: 493
infinix note5 x604 mt6763 da needed to reset frp sucessfuly
Old 09-05-2018, 14:00   #4 (permalink)
Member: 2211790
Thanks Meter: 5,118
Use CM2 MT2 R4 version select tecno do operation and post logs
Old 09-05-2018, 20:09   #5 (permalink)
Member: 2812901
Thanks Meter: 493
do l need to update this version of cm2 0137.02
Old 09-06-2018, 03:14   #6 (permalink)
Member: 2211790
Thanks Meter: 5,118
Yes for run Mt2 r4 dongle firmware must be this
Old 09-06-2018, 09:05   #7 (permalink)
Member: 1628342
Sonork: 1592100
Thanks Meter: 38
as for da file for that model contact me
Old 09-06-2018, 10:59   #8 (permalink)
Member: 2812901
Thanks Meter: 493
this is my dongle version cm2 v 01.37. is any version higher than this? becuase i want upgrade it. it expired on 16:8:2018.
Old 09-06-2018, 11:42   #9 (permalink)
Member: 2812901
Thanks Meter: 493
pls team is that any version higher than 01.37 for cm2 ??????
Old 09-06-2018, 11:47   #10 (permalink)
Member: 2211790
Thanks Meter: 5,118
today is 6/9/2018 so your activation is expired
renew it and update card
Old 09-06-2018, 11:48   #11 (permalink)
Member: 2211790
Thanks Meter: 5,118
Old 09-06-2018, 11:52   #12 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello,
Download Mt2 r4 found on support and use.
You have latest firmware version already.No need update.
Old 09-06-2018, 12:05   #13 (permalink)
Member: 1677653
Thanks Meter: 2,769
U can still use cm2 mt2 r4, just download it from support download area
Old 09-06-2018, 13:52   #14 (permalink)
Member: 2812901
Thanks Meter: 493
samsung g7 prime show an error as occurred after reset FRP by cm2 pls what do i do?
Old 09-06-2018, 15:11   #15 (permalink)
Member: 1677653
Thanks Meter: 2,769
Next time create thread for each problem and also post log for help
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Page generated in 0.19371 seconds with 8 queries
