07-07-2016, 08:38 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | Da_error Start at : [07/07/2016 / 09:08:05] Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 119 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 5600017030303031E3305038F1D6587F Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed PLZ HOW CAN I SOLVED THIS PROBLEME |
07-07-2016, 08:40 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Remove battery. Press need operation button. Insert usb cable. Insert battery fast. Not press any button on phone. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
07-07-2016, 10:31 | #3 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | its ok thx Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 5600017030303031E3305038F1D6587F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 7001005631303030385030E37F58C2F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB] DEV RID : 0xDE96B4FFC24E9C3059A1DD7DE44791F1 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
