09-10-2017, 06:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1358365 Status: Offline Thanks Meter: 19 | [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! plz help me |
09-10-2017, 07:06 | #2 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Earth Age: 24
Member: 2425283 Status: Offline Thanks Meter: 95 | your problem for all device? or just one device? if your problem with all device remove mtk module and install again if one device maybe device not supported |
04-13-2018, 13:10 | #3 (permalink) |
Junior Member Join Date: Mar 2018 Location: Bangladesh
Member: 2819658 Status: Offline Sonork: +8801744268333 Thanks Meter: 2 | lava iris 41 mt6570 solution plz 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
04-13-2018, 15:56 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Change DA with latest spft or from firmware folder if present and check result. Or wait for update. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
12-12-2018, 07:16 | #5 (permalink) |
Junior Member Join Date: Aug 2010 Location: Bangladesh, Bagerhat.
Member: 1378819 Status: Offline Thanks Meter: 4 | [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! kicu kicu set a ai sommosa hoy...plz help |
