06-08-2017, 06:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | [DA_ERROR] : DRAM Configure failed! HANDSET WAS HANG ON LOGO.. I HARD RESET IT.. NOW SET IS TOTALLY DEAD...NO CHARGING SYMBOL ONLY RED LIGHT. TRIED 4/5 FIRMWARE BUT SAME ERROR IN SPFT... TRIED WRITE PRELOADER IN CM2... LOGS.. User selected Preloader file : preloader_wt98735_a1.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 150100523832314D42 , Name : R821MB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513832334D42 , Name : Q823MB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 70 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D31323868C90042D91040CC Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! |
06-08-2017, 08:27 | #4 (permalink) |
No Life Poster Join Date: Jul 2011 Location: dunia antah berantah
Member: 1616754 Status: Offline Thanks Meter: 245 | IC emmc problem bro...change it just remember,next time if you have same problem like hang logo,check fist with CM2 with option tab Format if you get "format userdata failed" usually its emmc... |
09-02-2020, 17:55 | #6 (permalink) | |
Freak Poster Join Date: Jan 2018 Location: Ghana
Member: 2803071 Status: Offline Thanks Meter: 46 | Quote:
The Following 2 Users Say Thank You to elmowaldo For This Useful Post: |
