02-03-2018, 09:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Online Thanks Meter: 129 | DA_ERROR] : DRAM Configure failed! Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:41 Reconnect Power/Cable! Operation : Flash Erase [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D3132386D2E0042E137DEE0 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:44 Reconnect Power/Cable! |
02-03-2018, 09:24 | #2 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | same problem here team where are you? Start at : [2/3/2018 / 10:46:18 AM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B594C30304D12B71F45815F6D Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2004 EMICFG_UNKNOWN_ERROR Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to shazzmob For This Useful Post: |
02-03-2018, 09:27 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | On both cases need try select fw or preloader with compatible DRAM. Normally that is device original FW. Or connect WITHOUT holding side keys. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
02-03-2018, 09:40 | #5 (permalink) |
Member: 1215266 Status: Online Thanks Meter: 129 | . CPU: MT6735 SW:0000 Ver: CA00 Downloading Boot11 ... EMMC Size: 0x03A3E00000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x80000000 Reading infr(EMMC)... version:5.1 id:amigo3.1.0 model:G6 brand:CLARESTA manufacturer:CLARESTA PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 LK BaseAddr:0x1C80000 Size:0x80000 PARA BaseAddr:0x1D00000 Size:0x80000 BOOT BaseAddr:0x1D80000 Size:0x1000000 RECOVERY BaseAddr:0x2D80000 Size:0x1000000 LOGO BaseAddr:0x3D80000 Size:0x800000 EXPDB BaseAddr:0x4580000 Size:0xA00000 SECCFG BaseAddr:0x4F80000 Size:0x80000 OEMKEYSTORE BaseAddr:0x5000000 Size:0x200000 SECRO BaseAddr:0x5200000 Size:0x600000 KEYSTORE BaseAddr:0x5800000 Size:0x800000 TEE1 BaseAddr:0x6000000 Size:0x500000 TEE2 BaseAddr:0x6500000 Size:0x500000 FRP BaseAddr:0x6A00000 Size:0x100000 NVDATA BaseAddr:0x6B00000 Size:0x2000000 METADATA BaseAddr:0x8B00000 Size:0x2500000 SYSTEM BaseAddr:0xB000000 Size:0xB3800000 CACHE BaseAddr:0xBE800000 Size:0x19000000 USERDATA BaseAddr:0xD7800000 Size:0x2CB580000 FLASHINFO BaseAddr:0x3A2D80000 Size:0x1000000 >>Done. |
02-03-2018, 10:14 | #6 (permalink) |
Member: 1215266 Status: Online Thanks Meter: 129 | Card found : S/N : A69C273F , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6735 , Project : gnbj6735_66t_l1 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D3132386D2E0042E137DEE0 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:01:04 Reconnect Power/Cable! |
02-03-2018, 11:41 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @tornado779, back to school. Base level - reading technique. Basic English. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
