03-30-2017, 14:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2552835 Status: Offline Thanks Meter: 8 | [da_error] : Securityboot_boot_not_accepted I have a problem with some MTK phones. specially after changing EMMC on g610. I recieve this error: Card found : S/N : D4DACA84 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! in this situation I can do nothing. not even read info. (and not write firmware, write imei,...) but phone normally works. in this situation I use volcano for imei (that is not permanent) - use dload for some models like g730 for write firmware - unlock bootloader. after solving this error by unlocking BL on h30-u10, I guess that other problems should be solved, and I think it should be a security lock or so. Has Any one any solution? BR |
04-01-2017, 08:21 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Huawei phones not supported much, only few of them supported. You can try to repeat operation with both volume keys pressed. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
