[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Solution Here Download all secure boot agents here 1. Rename bin file name in folder after extract as 'MTK_AllInOne_DA_SP.bin' 2. Replace 'MTK_AllInOne_DA_SP.bin' file in C:\InfinityBox\CM2MTK\Boot folder with your newly renamed bin file. 3. You are now ready to work with your phone. Good luck NB: Make sure to backup the original normal boot agent to work with normal phones or else, tool must be reinstalled to work with normal phones. EXAMPLE Code:
PHOTOS FOR THOSE WITH READING IMPAIRMENT PLEASE NOTE DOWN THE FOLDER LOCATIONS IN PHOTO CAREFULLY USING MOBIWIRE AS AN EXAMPLE https://s26.postimg.org/thzsphzmh/Untitled.png |
hello .... whats going here !!!!!!!!!!!!!! hello infinity team ........ pls say something about this post. thanks, |
solution must have preload in firmware to boot DA MTK i do not understand much about this thanks |
You need an extraordinary comments or magical words? Quote:
You need an interpreter, magnifier, microscope or telescope? All files needed are already provided in the download link above. PM me your remote viewer id name. |
Index of ./VolcanoBox/Volcano_Inferno_Updates/Inferno_MTK_Module_Updates/Inferno_MTK_Manual_Boot/ |
All files are encrypted and only use-able with other tool.Peoples should do real work from their own hands before spreading out anything :) BR. SeharH |
If you share too, you are disturbing. What is it that we should do now friends? I think you should create a new thread with this your problem for help. It's all noisy in this thread.:) |
BR. SeharH |
I have said it and will say it again and again to simply create a new thread with this your problem for help:cool: |
not working Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
Extra Tips If tool says 'BootLdrSS : SIGNED with SPRELOADER' rename DA AGENT file downloaded for the particular phone model as 'MTK_AllInOne_DA_SP.bin' and replace in 'C:\InfinityBox\CM2MTK\Boot' folder If tool says BootLdrSS : NORMAL with PRELOADER but still says [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED rename DA AGENT file downloaded for the particular phone model as MTK_AllInOne_DA.bin and replace in 'C:\InfinityBox\CM2MTK\Boot' folder |
is this secure boot files work correctly with Huawei MTK devices ? |
we will see and wait hope it will be provided soon or shall we say they already have it in a dream of the next update |
