Old 10-06-2017, 00:50   #1 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,115
Thumbs up [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Solution Here
Download all secure boot agents here
1. Rename bin file name in folder after extract as 'MTK_AllInOne_DA_SP.bin'
2. Replace 'MTK_AllInOne_DA_SP.bin' file in C:\InfinityBox\CM2MTK\Boot folder with your newly renamed bin file.
3. You are now ready to work with your phone. Good luck
NB: Make sure to backup the original normal boot agent to work with normal phones or else, tool must be reinstalled to work with normal phones.
EXAMPLE
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Boot Error!
Operation Failed
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-06-15.11:02
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464E58324D4201273ADC0A24C1
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D4201273ADC0A24C1
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0x821AAA71CC5948285E41B48DCC641775
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:26
Reconnect Power/Cable!
The Following 11 Users Say Thank You to Kwesi_Roy_GH For This Useful Post:
Old 10-06-2017, 01:43   #2 (permalink)
dirty_dude41's Avatar
Member: 1473466
Thanks Meter: 89
EXAMPLE
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:26
please make sceenshot to see whats going on, especially after extract and renaming files.thiers no such file MTK. thanks sir.
Old 10-06-2017, 01:57   #3 (permalink)
Member: 2575234
Thanks Meter: 1,115
PHOTOS FOR THOSE WITH READING IMPAIRMENT
PLEASE NOTE DOWN THE FOLDER LOCATIONS IN PHOTO CAREFULLY
USING MOBIWIRE AS AN EXAMPLE
The Following 2 Users Say Thank You to Kwesi_Roy_GH For This Useful Post:
Old 10-06-2017, 03:49   #4 (permalink)
Member: 1128573
Thanks Meter: 232
hello .... whats going here !!!!!!!!!!!!!!
hello infinity team ........ pls say something about this post.
thanks,
The Following User Says Thank You to mahir ashab For This Useful Post:
Old 10-06-2017, 04:54   #5 (permalink)
Tien Dung GSM's Avatar
Member: 2643704
Sonork: Zalo:0932606079
Thanks Meter: 92
solution must have preload in firmware to boot DA MTK i do not understand much about this thanks
Old 10-06-2017, 05:17   #6 (permalink)
Member: 2575234
Thanks Meter: 1,115
thanks,
What do you want to hear from team, man?
You need an extraordinary comments or magical words?
What do you still don't understand here bro?
You need an interpreter, magnifier, microscope or telescope?
All files needed are already provided in the download link above.
PM me your remote viewer id name.
The Following 3 Users Say Thank You to Kwesi_Roy_GH For This Useful Post:
Old 10-06-2017, 06:17   #7 (permalink)
khawajagsm's Avatar
Member: 639462
Thanks Meter: 379
EXAMPLE
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:26
don copy past others its give volcano-inferno
Index of ./VolcanoBox/Volcano_Inferno_Updates/Inferno_MTK_Module_Updates/Inferno_MTK_Manual_Boot/
The Following User Says Thank You to khawajagsm For This Useful Post:
Old 10-06-2017, 06:53   #8 (permalink)
SeharH's Avatar
Member: 2753718
Sonork: FB : SeharH Gsm Services
Thanks Meter: 373
All files are encrypted and only use-able with other tool.Peoples should do real work from their own hands before spreading out anything
BR.
SeharH
The Following User Says Thank You to SeharH For This Useful Post:
Old 10-06-2017, 09:37   #9 (permalink)
Member: 2575234
Thanks Meter: 1,115
Red face
Originally Posted by khawajagsm View Post
BR.
SeharH
If you don't share, you are selfish.
If you share too, you are disturbing.
What is it that we should do now friends?
I think you should create a new thread with this your problem for help.
It's all noisy in this thread.
Old 10-06-2017, 10:00   #10 (permalink)
SeharH's Avatar
Member: 2753718
Thanks Meter: 373
Your method is working perfect but the files you have share you should have to check before share to others
BR.
SeharH
Old 10-06-2017, 10:18   #11 (permalink)
Member: 2575234
Thanks Meter: 1,115
BR.
SeharH
I already checked those files before sharing it bro.
I have said it and will say it again and again to simply create a new thread with this your problem for help
Old 10-06-2017, 10:57   #12 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 146
not working
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
[DA_ERROR] : Correct BOOT CONFIGURATION not found for target!
Try Re-Install CM2MTK module!
Boot Error!
Operation Failed
Elapsed: 00:00:08
Old 10-06-2017, 11:43   #13 (permalink)
Member: 2575234
Thanks Meter: 1,115
Extra Tips
If tool says 'BootLdrSS : SIGNED with SPRELOADER'
rename DA AGENT file downloaded for the particular phone model as 'MTK_AllInOne_DA_SP.bin' and replace in 'C:\InfinityBox\CM2MTK\Boot' folder
If tool says BootLdrSS : NORMAL with PRELOADER
but still says [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
rename DA AGENT file downloaded for the particular phone model as MTK_AllInOne_DA.bin and replace in 'C:\InfinityBox\CM2MTK\Boot' folder
Old 10-06-2017, 12:06   #14 (permalink)
Member: 2012088
Thanks Meter: 8
is this secure boot files work correctly with Huawei MTK devices ?
The Following 2 Users Say Thank You to vitos747 For This Useful Post:
Old 10-06-2017, 13:41   #15 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 589
we will see and wait hope it will be provided soon or shall we say they already have it in a dream of the next update
Page generated in 0.40727 seconds with 7 queries
