03-14-2018, 11:36 | #17 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Tonga
Member: 2422331 Status: Offline Thanks Meter: 41 | A6600a40 change name as instructions and here my result Code: Card found : S/N : xxxxxxxx , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
11-01-2018, 17:46 | #19 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Accra-Ghana
Member: 1412214 Status: Offline Thanks Meter: 6 | Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! SIR PLEASE CAN U HELP I HAVE DOWNLOAD THE DA SECURE BOOT AGENTS |
