10-31-2015, 11:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Datawind Ubislate 7cz Hang @ Logo Problem:-HANG @ LOGO Need Firmware Plz Share It Code: Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 002C00440044004B00A9000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0046 , [MICRON] MT29F32G08CBADB [NAND] : FLASH_DIE : 002C 0044 0044 004B 00A9 0000 0000 [NAND] : FLASH_LEN : 0x100000000 [NAND] : FLASH_EXT : 2000/0100/00/ INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
03-02-2016, 08:10 | #3 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 1001290 Status: Offline Thanks Meter: 81 | all datawind firmware Quote:
